Gaggia Classic: important questions
  • #16
    Re: Gaggia Classic: important questions
    Margie;
    If you left a message, an I did not call you I can only apology, I try to call everyone at the same day after 3:30pm that is my call back time.
    The steam arms are not in stock due to lack of supply, I have received my order from Europe 2 days ago and there where not there. I am trying to get via other sources, but only time will tell.
    have you tried coffee parts, I just looked at his website and the link for you.
    http://www.coffeeparts.com/domestic-parts/machines/rancilio-silvia-08.html
    We will let you know as soon we had it back in stock or will be display in the website as soon we get it back.
    Regards
    Renzo
    • #17
      Goodness! - such loyalty. Most commendable.
      Bashing I think is a little over the top: more of a mild whinge, really.
      Now put firmly in my place.
      And yes, have found the Rancilio steam wand at Coffee Parts.
      • #18
        Margie, dont be discouraged by the small basket. Give it another go and has been suggested, just put a little less coffee into it.
        After a firm tamp, the level of the coffee should be 3-4 mm below the top lip of the basket. Overfilling it, even by a small amount, makes it very difficult to lock into the machine.
        Using the smaller basket gives you a different coffee experience, consider:
        [list bull-blackball][*]You can grind a little bit coarser  as there are fewer holes in the bottom of the basket so the hot water already has some increased resistance to get through. This will give you a different flavour.
        [*]The coffee is a little less intense - and sometimes you want that with a shot - you dont need every coffee to be flavour saturated. Sometimes you want a lighter coffee.
        [*]You can offer a bit more choice to your guests.[/list]
        Cheers.
        • #19
          I found this with my Classic standard small basket.
          I got a new small and normal basket from Greg Pullman at the same time as I got my tamper (many years ago) which have proved to be fantastic.
          The small basket is not at all fussy about getting the dose exactly right. It has a deep but half size shape and clips into the handle spring easer as well.
          • #20
            +1 for the Silvia steam wand mod. Should come standard :P
