Quaha Napoletana II - brew water not coming out of group?
  • artman
    Re: Quaha Napoletana II - brew water not coming out of group?
    Yep, you can take the coil assembly off (which I did when everything was stripped). I was going to take it apart but the hose barbs looked very clean so I left it.
    They look just like the fuel cut off solenoids on LPG car systems, except slightly smaller, I have renewed a few of them in the past, there is nothing to them really.
    Wont be able to have a play with the machine until next week unfortunately but will report back my finiding.
  • KJM
    Just to add to Chriss comment - most of the 3 way valves Ive taken apart actually are repairable. You can normally unscrew the "end" and the whole gubbins is accessible. Im with you though artman - Id bet it is just crudded up. Clean and maybe lube and itll come good!
    It is Australia day afterall - youve got the time
    /Kevin
  • artman
    Thanks Chris, I will take the solenoid apart and see what is going on. I didnt realise the 3 way valve also diverts water between the group and stem tap.
    The insides of the boiler etc were quite clean, hardly any scale.
    Thinking about it now, I guess it probably is sticking from not being used for a while (just like the vibe pump was), and just happened to function that one time.
    Probably a dud solenoid coil or jammed solenoid per favour of your descale.
    If you have the knowledge, test the coil and if all is well, disassemble and clean the solenoid.
  • artman
    started a topic Quaha Napoletana II - brew water not coming out of group?
    I recently picked up a Quaha Napoletana II from a very generous CSer, I striped it down and gave evrything a clean and descale, freed the vibe pump and got it working.
    When I put it all together, I tried running a brew but the water would not come out of the group, only via the steam tap if openened. I realised I didnt connect the wires to the 3 way solenoid. I connected them up and everything worked fine.
    Then the next time I tried it the problem resurfaced. Water does not come out of the group when the brew switch is on (pump working fine - water comes out via OPV as system has no outlet), and I can open the steam tap and water comes out there ok.
    Any ideas what is going on?
