Hi guys,
I just bought second hand Em6900 coffee machine with em0480 grinder,
I knew i should not have bought it after reading so many posts about how trouble it is..
However, i did buy it and tested.
somehow for first 5 cups testing it worked fine although it was under extracting and i realised i was not grinding fine enough
i did overcome this by grinding more fine and little bit of up dosing.
although steamming was not great,, made whole lot of bubbly foam only at top..
i do produce fine cup of coffee when i use indutrial machines.
first time for home machine though,
however, after 5 cups i decided to rest and turned machine off.
when i came back and turned it on again it was on standby mode more than 30 min and would not work.
then i decided to leave it for overnight
today i tried again it worked.
but the steam wand somehow only squrts water no steam at all..
i can still make espresso and hot water wand works but only steam wand does not work.
and again after turning it off trying to turn it on again its on standby mode forever.
i am very frustrated and disapointed..
please help me out here guys..
thank you for your tolerance of my stupid second language and long story.
Eric,
Eric,
this is really frustrating,,
