just bought a second hand Em6910 is this normal?
  • just bought a second hand Em6910 is this normal?
    just bought it and after a few shots, and after hours on this forum decided to check the shower screen and clean it. My question is after cleaning the verry black inner screen noticed that the head i think you call it? under the machine had also a lot of caked coffee. see attachments is this normal??
    Re: just bought a second hand Em6910 is this normal?
    Originally posted by 7F60676A6C677366313A090 link=1331813360/0#0 date=1331813360
    just bought it and after a few shots, and after hours on this forum decided to check the shower screen and clean it. My question is after cleaning the very black inner screen noticed that the head I think you call it? under the machine had also a lot of caked coffee. see attachments is this normal??
    Its normal up to a point to have some soft residual layer of coffee on it
    Clean it as well
      these pics are after i tryed to clean it. anything in particular i should use, seems to have a bit of corrosion sortof.. will probably do a backflush clean also..
        Do a clean with back-flush detergent certainly
        As for the pitting - Give it a careful rub with steel wool and detergent to get it as smooth as possible
          thanks will give it a go...
            If the group head is fairly filthy you can probably assume the previous owner didnt clean regularly. Id recommend a chemical flush as well as a descale. This should ensure all the crud is out and the pumps etc can work at their full capacity. Search around this site to find different opinions on the right chemicals to use for each of these, there are quite a few opinions.
              Pretty normal, theyll look like that after about 8-12 weeks of moderate use. 6910 is an easy machine to clean though, and agree re: steel wool post. Works great.
