Low pressure on EM6900
  • Low pressure on EM6900
    Hi,
    7 year old EM6900 (one of the last) and EM0480 grinder.
    I seem to have low or reduced water pressure group head.
    The machine has worked consistently well and predictably on a 12 - 15 grind producing a 25 - 30 sec double shot in the 2 o clock position. perfect, steady, like clockwork for its whole life.
    Lately, it is almost impossible to prevent the gauge from going into the red and pouring 45-60 second trickle shot.  I have also stepped the grinder back to 19/20 and cannot even tamp. I updose and level off the top lightly.  Any kind of tamp basically blocks the shot so nothing comes through and not updosing gives you a soaking wet puck.
    It has never had to be anywhere near this coarse in the entire 7 years I have had the machine, no matter what coffee i have used.
    On an empty basket the water appears to come through normally, but Im not sure.  I wondering whether the water flow is restricted in someway which is causing the gauge to shoot into the red zone.
    Does anyone have any suggestions before I make the trek out to Seven Hills to get it looked at?
    rdu
    Re: Low pressure on EM6900
    rdu,
    Welcome to Coffeesnobs.
    Are you using a double walled filter with a blocked lower hole? If so, clear the hole with a needle.
    Double walled filters are made to get fake crema from stale coffee and are supplied with the cheaper machines.
    It is better to get a single walled filter and to use fresh beans.
    Also have you cleaned  the machine recently, in the way recommended by Sunbeam?
    Barry.
      Hi there. Im a long time reader, first time poster
      Im using the original filter. I ripped the plastic insert out pretty much when I bought the machine on the recommendation of this forum, so thats not the issue.
      Ill try the clean tonight to see if that helps.
        If your filter basket is dual walled, single walled ones are available on evil bay.
        Barry.
          aah, i see what you mean. no I dont believe so. Im using one I bought from coffeeparts a few years ago. will check.
