Combined Rancilio espresso and grinder machine
  • Combined Rancilio espresso and grinder machine
    Howdy CSers,
    Yesterday I was at the Prahran market.  My eyes nearly popped out when I saw a Rancilio machine which had both the espresso machine (Silvia) and the grinder (Rocky) built into the one unit.
    Has anyone got any information on this 2-in-1 product?  Its almost like the folks at Rancilio have just combined the Silvia and the Rocky together into one.  What do you call this machine?  Miss Rocky?   ;D
    Re: Combined Rancilio espresso and grinder machine
    Were both units separate (i.e. side by side) on a stainless steel double drawer unit underneath....?
    That has been available for a while O/S - not sure about in Oz...
      Hi JavaB,
      No its not the two separate units with the stainless shelf and two side by side drawers.
      This Rancilio unit was both a grinder and an espresso machine combined as one, i.e. the sheet metal enclosed both together, so its not even like a siamese twin, where theres two distinct parts joined together but a single unit with two functional areas.
      Kinda hard to describe and ****** do not allow photography inside their shop.
        Must be the Rancilio Lucy.
          This is most bizarre, I cannot find this unit on Rancilios website.
          They just have the Silvia and the Rocky as separate units
          http://www.rancilio.com/rancilio/prodotti.jsp?id_language=3&id_category=26
          Ill give the Essential Ingredient people a call to find out more about that machine.
          Stay tuned.
            http://www.coffeegeek.com/reviews/co.../rancilio_lucy
            Try the above. Does it look like that one?
              Originally posted by tempestv8 link=1176692682/0#2 date=1176693693
              Hi JavaB,
              Kinda hard to describe and Essential Ingredient do not allow photography inside their shop.
              Maybe a chinese "knock off"....
              I cant find any details anywhere (on official sites that is) of such a machine either......
                Ahhhh.... maybe thats why I couldnt find it .... its a lucy rather than silvia :
                  No its real. But I would never like to have a grinder and machine in one. The heat from the machine will adversely effect the grinder and coffee.
                    Yes, Id agree there Wushoes. The "combined" unit on the base is fine..... but built into the same case heating of the beans is a big problem.... plus if one half fails the whole unit is out of action until repaired.....
                    Might save some bench space.... but I dont believe it is worth it.
                      Ive got an all in one case machine and never had a problem as I only put beans in as I used them. a 200g hopper makes sure of that. Id also suggest that even if you have them seperately, then if one fails the whole lot is out of action. I cant make espresso without my grinder, and I dont grind if theres no machine to use it in, so I think this is a bit of a moot point.
                      Yes, if the machine had issues you could still do french press, moka pot, etc, but its just not the same & I know that personally, I wont bother.
                        Ive had a look at the picture, and YES, that is it.
                        Looks like Ive met Miss Sylvias older sister, Miss Lucy!
                          Heres a URL that Ive found which has the Silvia side by side with the Lucy
                          mod edit- non sponsor url removed- your Silvia selling sponsors can supply this machine
                            Oh, cute. It even has a built in tamper... :
                              Built in tampers are good if you do a mid tamp...otherwise theyre absolutely useless.
