Re: Help... is Silvia OK???
Congratulations on the birth of your boy Mossicaf.
But I am at a loss over the purpose of your post: You seem to be looking to diagonose problems which are not necessarily there.
If it aint broke, what is the problem?
-Robusto
And mine (well, ok, works) silvia is usually off when not in use also.
so long as the boiler is full of water and the machine isnt steaming, you shouldnt have any problems. I turn my machine off to save power and reduce wear on parts, otherwise it would stay on.Originally posted by mossicaf link=1181601712/0#0 date=1181601711Hi all,
A few months ago on my recommendation the company ordered a Silvia + Rock combo from the good people at Cosmorex here in Canberra.
I wasnt at work last Friday (my wife and I went to hospital where number 3 was born - a boy) and so wasnt able to supervise Silvia... so I come into work today to find that poor silvia had been left on over the long weekend!
I thought she had only been on since maybe 7am (got in late at 8:15am) so bled the steaming wand (took a while!).
She is now turned off and awaits your wisdom!!
My questions:
1) Is she ok??
2) What sort of problems might I expect?
3) What symptoms of (2) should I look out for?
Thanks in advance,
Graham aka mossicaf
(Oh poor Silvia, I am sorry I left you alone last week!)
Thanks Lizzie!
Toby is doing great, as is my good wife.
Graham
Congratulations on the birth of your son, Geofff!!
hope all is well
L
PHEW!
After a good rest I just warmed her up again ... she still heats!
The real test will come when I pull some coffee later today (when the beans arrive).
Good tip on the timer - just the thing for the office environment.
Graham
Is she still heating? If so, then youve gotten away with it. If not, then youll need to reset a switch and keep your fingers crossed that she hasnt blown the element. Details can be found here: http://coffeesnobs.com.au/YaBB.pl?num=1148872402
Either way, put Silvia on a timer - theyre under $10 dollars, and a lot cheaper than replacing the element, which also involves replacing the boiler. Attilio at Cosmorex would have explained to you that this isnt covered under warranty. Good luck.
My questions:
1) Is she ok??
Thanks in advance,
Graham aka mossicaf
(Oh poor Silvia, I am sorry I left you alone last week!)Tags: None
