I have a new SB6910 which was only purchased 4 days ago. I am finding that water often leaks around the filter and drips out the back of the group head, often carying the ground coffee with it. Now I am making sure that the handle is in tight and I check the pressure gage and it is staying in the center part. So does anyone know if this is a common problem I need to put up with or should I be ringing sunbeam. My gut feeling is to go with the later - is there any other suggestions. Also I am grinding the coffee in a 480 Sunbeam grinder on about setting 5.
Regards,
Nevin.
Regards,
Nevin.
