Rancilio parts & service in Melbourne?
  • #16
    Re:  Rancilio parts & service in Melbourne?
    Hi Simone
    Im surprised you didnt get a response from Coffee Parts - best bet would be to give them a call and speak to Pedro as he will "walk you through" the process.
    As youve discovered, food grade grease isnt always easy to come by. I use it for lubricating my roaster but it comes from the US in a grease gun tube size that might be overkill for your Rancillio.
    You could try a commercial kitchen supplier or give the following people (Fuchs) a call and ask for the nearest stockist of their "Geralyn food grade grease".
    http://www.fuchs.com.au/html/fuchs_locations.html
    If youre still stuck after all that, let me know.
    • #17
      Pretty sure that Pedro and Cilinia will be flat out preping for the AromaFest and may not be near their offices....
      • #18
        Hi Dennis,
        Thanks for that. I did finally manage to find a purveyor of silicone grease on this side of town (Blackwoods in Scoresby, if anyone needs to know )
        • #19
          I just saw this topic. Bunnings near me sells a product called doustgrease. It says it is foodsafe. It is a small tube. I havent tried it though as I already have some silicon grease.
          • #20
            Hi Damian,
            Thats interesting. I was about to hang it on our local Bunnings for being useless (it *was* the first place we tried), but in fact we did ask explicitly for silicone, and "doustgrease" is pretty coy about actual composition. Just says "non-petroleum".
            No MSDS on their website either. Wonder what it does in *hot* water?
            • #21
              Thata exactly what I was wondering (about in very high temps). I agree their website is quite vague isnt it.
              By the way, did you end up stopping your leak? I dont know if your valves are the same as mine, but I replaced with bits from here: http://www.coffeeparts.com/rancilio/ran2.html. I imagine 700308 would be your problem? I replaced this in my valve, but it still leaked. It turned out there was an inperfection in the brass where the gasket sits. A little sanding fixed that.
              Damian.
              • #22
                Ah yes - the dreaded 700308 :
                My steam wand seemed to dribble every which way, so everything rubber was deemed to be suspect (3 o-rings and the gasket). These were indeed replaced, with a certain amount of drama and rather more brute force than I mightve liked! I think my Silvia has been rather neglected in its previous life -- certainly the wand has been leaking a looong time. I had a vague plan of putting some pix up -- not sure how useful this would be to anyone else in my position, but the pile of tools at the end was impressive!
                Anyway, it all seems tove been successful - no more leaks Tho Im still coming to terms with my new "soft-feel" steam tap -- it doesnt need to be turned **OFF** like it used to, and even seems more enthusiastic when its on!
                With the coffeparts website, I think Silvia owners are probably better off starting at http://www.coffeeparts.com/machines/rancilio.html which lists the basic Silvia parts kit (as it were). The drawing on http://www.coffeeparts.com/rancilio/ran2.html doesnt quite match whats in the Silvia, and was the cause of a great deal of head-scratching when I belatedly discovered it (just as well it was belated, otherwise Id probably still be trying to figure out what I should order : )
                • #23
                  Sorry to dig up this old thread, but it has come my turn to perform said maintenence on my beloved Silvia. Could someone who has done this before quote the part number for the o-rings? The schematic has me stumped. 700352 maybe...?
                  Also, Ive noticed that when let the machine warm up till it reaches steady state(about half an hour), the valve becomes stiff to open. Has anyone else had this symptom?
                  • #24
                    Hi Jacko,
                    Site sponsors DiBartoli and Coffeeparts will both be able to assist with the required bits and postage to you...
                    Good luck
                    2mcm
