Bezzera going to sleep
  • Bezzera going to sleep
    Needed some help in relation to a 10 yr old single group machine just bought, all is working well though after being on for approx 30 minutes the green light goes outthough the power light still remains on, but the machine can not be used for quiet a while until it cools down so i need to shut it down and then restart it.
    Has anyone experienced this before? Otherwise it works well, i believe it is a high end domestic/ low end commercial machine, any thoughts would be appreciated.
    Thanks.
    Ang
    Re: Bezzera going to sleep
    Probably a low water auto cut off
    If your water is not low check that the switch is making contact
    If its a tank version sometimes the tank bends causing a gap in the contact point
    It is a s/steel plate to a large pop rivet like button
      Angboli;
      Sounds to me that the transformer from your control board is overheating.
      Best regards
      Renzo
