Re: bezzera domestic levermachine 1970s spare par
thanks Mal
that looks promising
james
bezzera domestic levermachine 1970s spare parts
As an interim measure JAHH how about visiting a local bearing supplies store with the exact dimensions of the O-Ring/Seal you need. You may be pleasantly surprised at the range of sizes and materials they will have on offer.... 8-)
This site has some useful information....
thanks graham
ive already had a chat to macello at euro and he had nothing suitable
the pavoni domestic is too small and the commercial too big
ive just had another look around on the web and come across what i think is a suitable part
its for the olympia cremina its 58 ext 48 int by 7 mm the catch is its out of stock at the place that had it on its spares list so : does any body know where to get a olympia cremina spare parts ???
thanks
james
the oring is an imperial size and is the same as used in the Lapavoni Lever
available from the importer (euroespresso not a site sponsor)on parramatta rd Syd
graham
Yea nice machine Jahh
This Bezzera is just middle age (a little younger than me)
I would want to keep it going for another 40 years or so
Wow! Pretty solid looking machine JAHH.... 8-)
Should have suspected this though, being a Bezzera
thanks all
int dia 48mm
exr dia 59mm
ididnt manage to put a pic up / this is pic of one like it on the web
http://www.home-barista.com/forums/nother-zzera-t2624.html
mine is orange and is tank only no plumb in option
coffee parts # 621303 should do your job
67 x 56 x 6mm oring style seal
if your pf a bit lose insert spacer # 700728 before seal
graham
James;
We replace the seal of one on this machines about a year ago, talk to Pedro from Coffee Parts he should be able to help you.
Regards
Renzo
hi james
do you have a pic of the machine
what is the approx size of the seal or the slot ID and OD
graham
erm- caps lock James? :-?
THANKS GUYS
I SAW A AN ELEKTRA MICROCASA A LEVA IN A COFFEE SHOP TODAY WHICH REMINDED ME THAT I USED AN ELEKTRA SPRING TO REPLACE MY BROKEN ONE AND THAT THE PORTAFILTERS ARE THE SAME SIZE , THE GROUP IS SIMILAR SO ONE OF THEIR GROUPHEAD SEALS MIGHT FIT
SO THIS IS WHAT I WILL TRY FIRST THEN ILL TRY AND MAKE ONE AS PER KKS INSTRUCTIONS
JAMES
A suitably thick O-Ring of the right dimensions would probably do a decent enough job as well....
Yep
You can also try a gasket place
http://www.segaskets.com.au/other/index.htm
Or just get some sheet rubber that is heat rated and cut one from scratch
as I did for the uncle
No one will see it up there so you don’t have to be to pedantic about appearance but still do an acceptable job
You can use a whole saw to drill the inside diameter first and use scissors to cut the outside
Method
Get a flat piece of wood drill guide hole
Nail rubber at corners to secure
Guide drill bit of whole saw into pre drilled hole and let the whole saw cut the rubber slowly (best if you also have a drill stand)
thanks kk
when you say cut to size what do you mean?
Ive not taken the seal out for ages for fear of irreparably damaging it, but the size is appprox 59mm x48mmm so its significantly smaller than any on the coffeeparts list,stingng so are you suggesting cutting a piece out of a similar diameter longer one?
thanks
james
