I guess it has been a while since I last removed the shower head (hasten to add that I have been backflushing, etc. and my head being like a sieve, I needed to Google for instructions, just in case something needs doing I forgot. Now I wish I hadnt. I found this page: http://www.jetblackespresso.com.au/e...ncilio-silvia/ and attempted to follow the instructions, however the only thing that "fell out" was the shower screen. The brass water dispersion ring wont budge. So, I did some more Googling and found http://coffeegeek.com/forums/espresso/machines/39475 So, my question is, is the water dispersion ring removable or not?
Stuck while cleaning Silvia
Re: Stuck while cleaning Silvia
Yes, it should just fall off once youve removed the shower screen. If its been a long time since you removed the shower screen the dispersion ring may be stuck on by the gunk thats built up. Youll have to try shifting the dispersion ring with a bit more force, I guess. Or maybe if you can slip something under the side you can lever it off? But theres nothing mechanical holding it on once the shower screen comes off, so if you can loosen it sufficiently gravity should do the rest.Originally posted by Judy link=1227458536/0#0 date=1227458536So, my question is, is the water dispersion ring removable or not?
I think it depends on what model Silvia you have. I know that part is removable on the newer model (2007 onwards, ie. the POD adaptable one) but I dont think it was removable on the models before that.Originally posted by Judy link=1227458536/0#0 date=1227458536So, my question is, is the water dispersion ring removable or not?
Actually, what I said wasnt entirely correct. There is a stainless-steel "water spreader" that should come out as well.
That brass piece shown in the 5th photo on that first link of yours is only applicable to the later model Silvias. In the earlier models that piece is integral to the grouphead and not removable.
The stainless-steel piece shown in the 7th photo though IS removable in ALL Silvia models.
I hope that clarifies things for you.
Thanks for clarifying that, Bill. I have a newer model Silvia, so the brass dispersion ring does come off. Obviously Judys is the older one. Well hopefully - at least that would explain why her dispersion ring isnt detaching.
Hi Judy,
Hope the Silvia clean is going well. I have edited the cleaning instructions to make note of the fact that on older Silvias, that brass disc is part of the head and wont "drop out". The Silvia in the photos was a 2007 model, just prior to the OPV adjustable model of 2008.
charlie
Actually the OPV adjustable model came out in 2007. I know this because the one I bought one in 2007 had the adjustable OPV on it.Originally posted by JetBlack Espresso link=1227458536/0#5 date=1227483887The Silvia in the photos was a 2007 model, just prior to the OPV adjustable model of 2008.
Aha! Mine is 2005.Originally posted by Bill link=1227458536/0#2 date=1227476093I think it depends on what model Silvia you have. I know that part is removable on the newer model (2007 onwards, ie. the POD adaptable one) but I dont think it was removable on the models before that.Originally posted by Judy link=1227458536/0#0 date=1227458536So, my question is, is the water dispersion ring removable or not?
Yes, thank you very much. All the other bits did come off, it was just that copper bit that didntOriginally posted by Bill link=1227458536/0#3 date=1227481035Actually, what I said wasnt entirely correct. There is a stainless-steel "water spreader" that should come out as well.
;D I didnt realise I found instructions from a fellow snob ;D To be honest, I didnt even notice the "au" at the end of the link. It is a very good, clear instruction. Thank youOriginally posted by JetBlack Espresso link=1227458536/0#5 date=1227483887Hi Judy,
charlie
Thank you everyone for the help. Just as well I am "detoxing" atm (well, trying to get into a dress by Sunday, for a wedding Im going to
) so Im only drinking this lemon drink - no coffee, otherwise I would have been most upset about my Silvia it bits for a day. :
