Backflush Miss Silvia?
  • #16
    Re: Backflush Miss Silvia?
    Until you get your own, quality espresso grinder you will just be playing at espresso. First, if you can get a good pull with coffee ground off-premises, you should head for the nearest casino, because you are chuck-full of luck. Second, once coffee is ground it has about twelve good, fresh minutes (on a good day) before it is too stale to be used for espresso. For me, I grind per shot and it has about one minute between grinder and extraction to live.
    The espresso machine is an accessory to the grinder.
    I have made some very drinkable espresso using a Rancilio Rocky and a Krups 863 espresso machine I bought, used, for about $7.
    Get thee off to a shopkeepers establishment in the village and barter for thine own grinding device, forthwith.
    • #17
      kel,
      as has been suggested if you can pick up a good grinder (at least a Rocky but could try a 0480), it will transform your shots, but until you get one and have a play and experimenting you wont fully understand how much of a difference it makes to your coffee!!
      I had a 4800 cheap espresso machine, and then I upgraded to a Silvia & Rocky combo, but tried my old machine with the grinder and it made such a massive difference!
      If you can steal or borrow a friends grinder and have a play at home with your Silvia and then you can see for yourself
      • #18
        Ok, you convinced me, went with the Rocky. There were cheaper, but might as well spend a bit more and be satisfied with the purchase.
        Still havent received the other supplies yet though...I hate the post sometimes!
        • #19
          rocky will be great for your silvia, mine is. but if the grind is to fine i would be making sure with a thicker grind it speeds it up a bit
          • #20
            +1 here on the Rocky. Mine is and I reckon its good enough for your next espresso machine upgrade.
            • #21
              kel you wont regret your decision.
              enjoy your new grinder and may it improve your shots and bless your Silvia.
              • #22
                agree completely with the posts above, had a silvia and rocky (doseless) combo now for almost five years and been very happy with the results. also agree with the back flushing, i do it with water once a day (min) and do a chemical back flush once a month.
                DD
                • #23
                  As with anything regular maintenance will keep ur machine happy for a much longer time!
                  • #24
                    Still waiting for my stuff, they had some of it on back order. Yeesh!
                    • #25
                      Did some cleaning with some Cleancaf, got some nice brown gunk out of the machine, changed out the screen, ran several reservoirs of water through, I think this will make a difference.
                      I didnt realize, when I bought it, that Cleancaf was more of a annual type of cleaner, so Ill purchase a more general cleaner to drop into my portafilter later.
                      My Rocky hasnt arrived yet, but it should be here Friday. Thats what I"m very excited about!
                      • #26
                        good stuff, let us know how you go and if the flow rate improved
                        • #27
                          have you tried any shots yet? did cleaning it fix the flow problem??
                          • #28
                            Flow rate has improved immensely! Thank you for the help and advise.
                            And today my Rocky arrives! Its going to be a good weekend
                            • #29
                              Youll be very pleased Im sure
                              Maybe a little patience as you experiment with dose, grind and tamp, but you will get there.
                              Have a great weekend
                              • #30
                                hmmmm is the room vibrating. Love my grinder, thanks again all! ;D
