EM 6910 - brass showing in portafilter, dripping water nozzle.
  • A_M
    Re: EM 6910 - brass showing in group handle, dripping water nozzle.
    Originally posted by 4F45484B4B484546494146240 link=1250476712/5#5 date=1250600660
    Originally posted by 527D7476615E727D7274767E767D67130 link=1250476712/3#3 date=1250517866
    2: Let us know as to Group and getting drip in H Water and when you run Hot Water, what happens on teh Group ?
    The group doesnt drip - I ran it for a minute, and filled two latte glasses to the brim.
    So it still leaks a bit from the HW when making a coffee ?
    If so, there is a small valve in the main group head that can have a slight impact but usually for when water comes out the Head, when running HW.
    As the knob opens and closes a valve, the only other thing I can quickly think of it that a bit of scale or crap has made its way into HW valve...
    Unless you very happy with pulling apart... I would not go there.. So where are you located ?
    If only a drip... Wait until ya next clean and descale and run the HW so that the cleaning agent etc gets to make it way via the HW valve / tap..
    Let us know how you go..
    PS. Dropped two groups in to be re chromed (1 = heavy use) and cost me $40... So @ $20 a group = OK cost to have them like new again.
    The second one was a Naked EM6910 group, that I modified to take out the step in teh lug... So it should come back as new and all teh machining marks from being Naked will also be done...
  • kaloolabmeb
    Originally posted by 76525B5B58586276524E50523D0 link=1250476712/4#4 date=1250517935
    Brass wont kill you
    Most household taps are made of it + water runs inside copper pipes
    Relax & drink the coffee
    Thats what I wanted to hear!
  • kaloolabmeb
  • Koffee_Kosmo
    Originally posted by 4B414C4F4F4C41424D4542200 link=1250476712/2#2 date=1250516447
    Thats what I was concerned about - whether having the exposed brass would do something to the flavour (or be dangerous - I dont really know much about the chemical effects of these metals).
    Brass wont kill you
  • A_M
    Originally posted by 58525F5C5C5F52515E5651330 link=1250476712/2#2 date=1250516447
    Issue 1:
    Well, its a relatively new machine, so I was a bit surprised.  Its wear rather than anything else - its not coming off in sheets.
    If it doesnt affect the coffee, and is just cosmetic, then I dont care (particularly since it is inside the portafilter!). Thats what I was concerned about - whether having the exposed brass would do something to the flavour (or be dangerous - I dont really know much about the chemical effects of these metals).
    Issue 2:
    Thanks for that - it sounds like a highly plausible explanation.  Ill try it out.  It is due for a descale.  They say every six months, so it is really one month overdue.
    1: Not 100% normal but to be expected... Some are better than others..
    AM
  • kaloolabmeb
    Issue 1:
    Issue 2:
  • A_M
    Originally posted by 3E34393A3A393437383037550 link=1250476712/0#0 date=1250476712
    Issue 1: Brass showing on inside of Portafilter
    Ive just noticed that the inside of the portafilter on my Sunbeam 6910 is losing its chrome - the brass is showing.  I have been cleaning it with Citric acid - but have only done this about 4 times.  Does it matter if the chrome comes off?  Will it affect the taste?  (NB - I removed the plastic thingy when I first got it - I believe someone here christened it the "Graeme".)
    Issue 2:  Dripping water nozzle
    The hot water nozzle has begun to drip when the machine is doing a pour.  Anybody else had this problem?  Does it get worse?  I am asking because I want to know if it is worth worrying about, as it is not causing a problem otherwise.
    The unit was purchased in January.
    A: Pealing off in sheets or just fading ???
    Many commercial units (hard core home ) that have been in use for some time have teh chrome worn away...
    B: Dripping water nozzle = possible lack of maintenance and correct cleaning agents etc OR lots of very fine coffee... Or some scale has come away..
    It gets in a little valve and allows water to flow in 2 directions rather than one...
    What happens if you turn on Hot Water and leave teh group out... After a while, do you get drips from teh group head ?
    Conclusions... Do a De Scale as per teh manual and then do a back flush as per the manual... Using correct cleaning reagents..
    Then test and let us know..
  • EM 6910 - brass showing in portafilter, dripping water nozzle.
