EM6910 Power Light Flashing Red
  • EM6910 Power Light Flashing Red
    Recently my Sunbeam EM6910 (nearly 2 years old) developed this habit of after the warm up period instead of a solid red light above the power button it keeps flashing (red). The machine still functions as normal.
    I have cleaned the machine using the Sunbeam products, (I clean it on a regular basis and use filtered water). I have done factory resets, occaisionally the factory reset makes it behave normally but for one use only. Cannot find any referance to this in the instruction manual and I was wondering if any one else has experienced this.
    Regards
    sjn
    Re: EM6910 Power Light Flashing Red
    Is it just in sleep mode?
    Sleep Mode
    After 1 hour of non-use the espresso machine will automatically switch to ‘SLEEP MODE’. An indication that the machine is in ‘SLEEP MODE’ is the lightabove the ‘POWER’ button will slowly flash red.
    Maybe its going to bed too early
      Thanks for your reply.
      In sleep mode the red light flashes slowly, mine however is flashing quite quickly and the green lights are all as normal.As I said before the machine is still functioning as normal just the red ligt continues to flash.
      sjn
        Sleep Mode
        Hey Rusty,
        In sleep mode the light above the power button slowly flashes green, not red, while all other lights are off.
        This appears a little different to sjns problem, which I must admit is one I have never seen before.
        Its like it is permanebtly sitting in one of the programming modes rather than reverting to normal after 5 seconds......wierd.
        Need AM to the rescue here me thinks....
          Page 24 of the manual says it flashes RED
            Yeah, just pulled the manual out and it does say that :-?
            Mine flashes green - in fact is doing so as we speak :-/
            What colour does yours flash?
              Oh you are awful :
              I just turned it on so Ill let you know in an hour
                Oh you are awful :
                ;D
                  sjn,
                  I would call sunbeam and ask them. The electronics probably use various flashes as error codes and only sunbeam are going to know what they mean.
                    Well there ya go, mines green also
                    Maybe the editor of the manual is colour blind
                      Classic ;D
                      Maybe the originals flashed red or something...
                      Originally posted by 53515D55555B5C41320 link=1251251711/8#8 date=1251345380
                      sjn,
                      Good call ACog, I think you may well be right. Shame they dont publish them so that people like sjn can get a handle on what is going on
                        +1 to ACogs advice - call Sunbeam, or your local service agent if youre on good terms. Probably a diagnostic code of some sort... or aliens trying to make first contact. Do the flashes spell out anything in morse code?
                        <thread hijack>
                        This reminds me of a quick question Ive been meaning to ask those who have had the Sunbeam in pieces... would it be easy for someone handy with a soldering iron to remove the LEDs... to swap them for blue ones for example?
                        </thread hijack>
                          <thread hijack>
                          </thread hijack>
                          A led strip if I remember ??? Send me a PM and when I get back, I will have a look on the weekend..
                          AM
                            Thanks to all for your input. I will call Sunbeam on Monday and report back here the result.
                            sjn
                              I have developed the same problem over the weekend, but not getting hot water, runs through cold, look forward to hearing the response you get.
