EM 6910 advice needed
  • EM 6910 advice needed
    Hi there,
    We have had a Sunbeam 6910 for a couple of years and recently a problem has started to occur with the steam wand. Basicly when we turn of the steam to the wand, it keeps issuing steam for quite a while (approx up to 30 secs). does anyone have any solutions to this problem or is this normal. If machine is needing a service who would people recommend in Adelaide to do the job?
    I might be willing to give a go myself if it is reasonably easy to pull machine apart.
    Re: EM 6910 advice needed
    Theres only one authorised Sunbeam dealer in SA, located in Park Holme. They were OK when my 6910 needed repairing, but very slow. You can get their details off the Sunbeam website, otherwise PM me.
    Coffee Craft used to repair Sunbeams but unfortunately no longer do. I would much rather have used them given the choice.
    I believe your problem is not uncommon. A search of the forum would probably reveal fixes for it. Otherwise Anger Management (our resident 6910 guru) will probably be along shortly to advise.
      mine does the same sometimes, seems to be when its on a dry steam setting more than wet (valve not closing properly?)
      You can "try" running scale solution through it, set steam thermoblock to coolest and steam to wettest, and only do it outside (maybe use the vinegar solution rather than a chemical one?) then run the steam at your normal settings a few times before using on milk agian.
      AM may be along soon with some other thoughts also
      Sen
        I had the same problem - used a descaler (not sunbeam) and ran it through the wand - problem fixed. The sunbeam descaler comes with a warning not to run it through the steam - but I got a commercial descaler which is approved for food devices. Some of the sponsors sell similar products.
        Hope this helps.
          Hope this helps.
          only run as stated by senator above... The fumes are nasty and can cause major problems... Also be aware that it can loosen crap and it can then get stuck in the steam pump. after that a major manual clean
          from my usless iPhone
