Re: 6910 - is this the end ?
Follow cksyd process ...
The issue is that the EM6900 had a copper lining and thus suffered but was easy to clean.
The EM6910 is SS lined and as such you need teh temp set to high to get good steam. This also means that SCALE can and will be a problem unless ya water is good.
The service agents in effect just use a syringe and manually pump and flush with a heavy duty descaler... No need to remove teh Steam thermoblock ( I would also not recommend - too much hard work).
This way the issue of WHS and fumes etc is not an issue. But you have to get access to the fittings at teh inlet to teh steam thermoblock. BE CAREFUL as you can break things.
That is why Sunbean do not recommend... As the fumes from some cleaning agents may be OK in a liquid BUT BAD when in a vapour and the USER desides to breath it all in ;D
