Re: EM6910 not setting itself
Thanks for waiting gentlemen
Here are more tests i did.
You talked about the situation being intermittent AM, i turned the thing on to see if it was heating up. Turned out it went back to normal, ie. Power light flashed, then all lights on, not blinking. Brew block felt damn hot. Thermoblock felt damn hot.
If this situation is an intermittent problem, it may be all is well now, but may and will re-surface in the near future.
When i rang service at Five Senses when it reared its ugly head again, he said its an intermittent problem. Cant fix it if unable to trace blame of source if its working well.
As promised, heres more pics with the multimeter, and im sure you will comment and advice AM. Thanks again.
Here is a list of results from resistance reading on the DMM logger:
Group element 47.30 ohm
Steam element 51.00ohm
Solenoid test 2.236 kohm
Red box thing (pump for brew??) .100ohm
Brew thermistor 87kohm
Steam thermistor 91.00kohm
Pics as follows:
Pics as follows:
(Photoshop is not a core app).
