Breville BES900 Dual Boiler - Owners thread
  • Re: Breville BES900 Dual Boiler - Owners thread
    Hi howser, For a double basket i am dosing around 3 or 4 on the grind setting and i am varing the dose depending on coffee beans.
    other factors to consider is what size shims are fitted.
    I think i have two 1mm shims fitted.
    When i have the right grind and dose i about 12 bar on the pressure gauge.
    Lenny
      Thanks Lenny,
      Havent fitted shims yet cause wanted to see how it went without.
      RE: dose quantity - how far up the double basket do you fill?
        Originally posted by 6C6B737761763D3D3D040 link=1312978609/196#196 date=1315096027
        Thats a good idea not to fit any shims until you see if it even needs them! Too many Smartgrinder users are fitting shims when unecessary.
        As for dose, a good starting point is when AFTER tamping the top edge of the cap on the Breville tamper is level with the rim of the filter basket. This will give you ~19g of coffee in a double. Remember this dose height is AFTER tamping and will be about 6mm below the rim of the filter basket & you need to hold tamp pressure constant, I use 15kg+
        See this video for some tips:
        http://www.youtube.com/watch?v=A4ByyUmZT28
        Once youve got the dose height nailed, you just need to adjust the grind size to optimise espresso flow rate. I use the shot clock as a starting point for this as well. If you see espresso start to flow from the spouts at 11-13secs on the shot clock, then itll be a pretty nice shot.
        Cheers, Phil
          Originally posted by 75726A6E786F2424241D0 link=1312978609/194#194 date=1315094313
          Barry, how much do you dose with your smart grinder?
          My scales tell me I am dosing with 15 g in the single dose single walled basket. The Smartie is set on the max amount for a single dose.
          After reading the following quote from phil I will try using less.
          Originally posted by 79777F7A7D737C6064140 link=1312978609/63#63 date=1313665336
          If you are weighing your shots, then this is ~10-12g for a single & ~18-20g for a double.
          Barry
            So got the first clean me today
            I thinks this means I have done 200 extractions that seems a lot for 2 weeks. I think it has counted all my purges and back flushes as extractions (I guess it is clever but not that clever)
            So I ran the clean cycle with the enclosed tablets, I thought I would use the my proper blind basket, but I think this may not have been a good decision owing to the fact it would appear that the 3 way dosent operate until the final rinse.
            Would seem therefore this clean cycle is about cleaning the brew head and is not intended as a chemical back flush.
            So I guess I am asking 2 questions
            if you do a clear water back flush after every session is the clean cycle necessary?
            and do I still need to do a chemical back flush?
              Originally posted by 485E024D0246025C454F47495E45424B2C0 link=1312978609/199#199 date=1315098133
              Have a look at Phils video on backflushing at:
              http://www.youtube.com/watch?v=_TpSSSYpq1I&feature=related
              Barry
                Originally posted by 012231313A1C07362D20222D430 link=1312978609/191#191 date=1315090816
                Great to see Pete from the USA here. Is the BDB available in the US yet?
                Barry
                oi!  i may be a yank, but i lived in oz for a bit meself.  and there are no two sports i like better than cricket and v8 supercars, so i have youz guys to thank for that
                sadly, the BDB is not available here here in the states yet, so im having to rely on my aussie mates here on CS to feed my fix, (and hopefully smooth out some of the bumps that come with a brand new bit of kit).
                -pete
                  Originally posted by 072437373C1A01302B26242B450 link=1312978609/200#200 date=1315100899
                  Barry
                  Thanks well aware of this video, and have been doing clear water back flushes with this and previous machines, not addressing the issue with the machine requesting a clean cycle.
                    After a slightly rocky start Im now getting great results with my Smart Grinder-Dual Boiler combo and couldnt be happier. Im dosing +2 bars on the smart grinder  and fineness (no shims) is set under the O in espresso. Pours are ~35 sec.
                    I do occasionally get a slightly damp/muddy appearance just on top of the puck. What part of technique do I need to focus on to fix that?
                      Originally posted by 4457425056250 link=1312978609/203#203 date=1315112265
                      After a slightly rocky start Im now getting great results with my Smart Grinder Dual Boiler combo and couldnt be happier. Im dosing + 2 bars on the smart grinder  and fineness (no shims) is set under the O in espresso. Pours are ~ 35 sec.
                      A slight increase in dose will solve that problem (and the associated coarser grind). But irrespective of how the puck looks, it comes down to how it tastes
                      Tim
                        Thanks Tim,
                        Taste is great, I have no complaints with what Im getting in the cup.
                          Originally posted by 6C4F5C5C57716A5B404D4F402E0 link=1312978609/198#198 date=1315097208
                          Hi Barry, if you like what youre tasting, keep doing it! Its all about what YOU like in the cuo. My advice was a bit generic, but if you like 15g from a single go for it.
                          Cheers, Phil
                            Originally posted by 54421E511E5A1E4059535B5542595E57300 link=1312978609/199#199 date=1315098133
                            Hi Doc, well it is actually that smart! It only counts extractions longer than 7 secs in the cleaning cycle counter, so youve actually extracted 200 times longer than 7 secs.
                            The "clean cycle" programmed into the machine is to be used with the silicon cleaning disk that allows some flow to be released from the group head.
                            If you clear water back flush after each use of the machine, then I would only use chemicals after every 2kgs or so. At this point I would also soak the group handle in espesso cleaner as well as you cant scrub every nook of rancid coffee oils thatll degrade the taste of any espresso.
                            Cheers, Phil
                              Hi Vince, that slightly wet cake you are experiencing is because our 3 way solenoid is mounted inverted. You can up-dose all you like, but youll still have some dampness. This is nothing to be concerned about. Changing dose should only be used to change the taste of the espresso if its not working for you.
                              Cheers, Phil
                                Thanks Phil, Ill keep doing what Im doing then
