Breville BES900 Dual Boiler - Owners thread
  • Re: Breville BES900 Dual Boiler - Owners thread
    I would also soak the group handle in espesso cleaner as well as you cant scrub every nook of rancid coffee oils thatll degrade the taste of any espresso.
    you can, if your portafilter is bottomless
    nudge, nudge, wink, wink
    -pete
      Originally posted by 7A69787F79796F66663F3A0A0 link=1312978609/201#201 date=1315101786
      sadly, the BDB is not available here here in the states yet
      Theyll have their initial stock in 14 days or so. Drop the Breville US office an email via their site www.brevilleusa.com & theyll be able to tell you who the stockists are.
      Cheers, Phil
        Originally posted by 434D45404749465A5E2E0 link=1312978609/207#207 date=1315114916
        Hi Doc, well it is actually that smart! It only counts extractions longer than 7 secs in the cleaning cycle counter, so youve actually extracted 200 times longer than 7 secs.
        Thanks Phil
        Ok that means I have drank a lot of coffee
        Come to think about it I am over 2kg in
        Aprox 40-50 shots per Kg plus I quess some of the backflush cycles are over 7 sec
          ok i have had the BES900 for a few days now and Im trying to work something out.
          according to the machine specifications, i should be dosing with 18g of ground coffee for a double shot and tamping with 15kg of pressure. what i cant work out is what difference the 15kg of pressure would make, as the tamper itself will only reach the indent of the basket (usually under light pressure). is this an indication that my grinder is set too fine?
          also the puck consistently sticks to the screen - which from what I have read is an indication of too much coffee in the basket. So does this mean i should be using less that 18g of coffee or is this an indication of grind size (as previously mentioned)?
          I would be grateful for any tips!
            Thanks for the feedback phil!
            One other quick question, which may seem silly - would you typically use a double basket to make a single milk coffee? My coffee has been quite strong so Im thinking that perhaps im oding....
              Originally posted by 544751564E4E4C4D47230 link=1312978609/213#213 date=1315139524
              Not according to Guru Phil
              Originally posted by 343A3237303E312D29590 link=1312978609/35#35 date=1313454700
              On some longer extractions, the cake seems to get stuck to the dispersion screen as there is some negative pressure being created when the 3 way solenoid opens to the drain as the solenoid is inverted. This is more pronounced with the 900 baskets as they have quite a taper & the puck releases very easily.
                Originally posted by 494E56524453181818210 link=1312978609/214#214 date=1315139664
                Again Guru Phil has answered this
                Originally posted by 0C020A0F0806091511610 link=1312978609/77#77 date=1313788469
                Having said all this, I get the best results with either one side of a double basket or a double ristretto. I havent used a single basket for 10 years....until I started to work for Breville, commercially, theyre just not used.
                Cheers, Phil
                  Originally posted by 293A2C2B333331303A5E0 link=1312978609/213#213 date=1315139524
                  If you check out this post is should cover your questions re dose/grind. What are you using to control dose? Are you using a Smart Grinder?
                  Originally posted by 333D35303739362A2E5E0 link=1312978609/197#197 date=1315097027
                  As for dose, a good starting point is when AFTER tamping the top edge of the cap on the Breville tamper is level with the rim of the filter basket. This will give you ~19g of coffee in a double. Remember this dose height is AFTER tamping and will be about 6mm below the rim of the filter basket & you need to hold tamp pressure constant, I use 15kg+
                  See this video for some tips:
                  http://www.youtube.com/watch?v=A4ByyUmZT28
                  Once youve got the dose height nailed, you just need to adjust the grind size to optimise espresso flow rate. I use the shot clock as a starting point for this as well. If you see espresso start to flow from the spouts at 11-13secs on the shot clock, then itll be a pretty nice shot.
                    there are some remedial questions coming up that dont have much to do with faults or foibles in the BDB, but are related to crafting shots of espresso in general.  being new here, i dont know if its appropriate to refer CS members to things like, "Espresso 101: How to Adjust Dose and Grind Setting by Taste" by linking to it?  i wouldnt want to go crook with the mods by inappropriately linking to another site.
                    -peter
                      Like this http://www.home-barista.com/tips/esp...te-t16968.html
                        Originally posted by 4D5E4F484E4E585151080D3D0 link=1312978609/218#218 date=1315171421
                        -peter
                        Haha dont get too worried about it. I believe that only commercial links are disallowed. So any information websites should be fine
                          Well my experiences
                          Tried the machine with CoffeeSnobs Espresso WOW!, and it is a very nice and smooth cup.
                          2 Problems I have ran into!
                          1. Puck always sticks the the shower screen! (I dont think I am overdosing, and I am always keep in line with the tamper.
                          2. Broken lid where the Water Fill area is!
                          I spoke to customer service this morning, and I have to now wait until it is fixed! Ahhh was enjoying it as well! I have only had the machine for a week!
                            Im think Im hooked.
                            I needed a second shot before I smiled this morning. Should I be concerned?
                              Originally posted by 3F293A262D31480 link=1312978609/221#221 date=1315180747
                              Well my experiences
                              Hi Warney, I was having the same problem and i was actually under dosing.
                              Make sure when you tamp the coffee is bang smack on the line in the filter basket no less.
                              I posted the same a bit back in this thread and phil said it was the 3 way v/v pulling a vacuum which sucks the cake onto the shower screen.
                              Hope this helps
                                Originally posted by 796F337C3377336D747E76786F74737A1D0 link=1312978609/216#216 date=1315141970
                                I think I phrased the question incorrectly. Im awfully confused. So, Ill be a bit more specific - using a double basket and dosing as per phils instructions, should I be getting ~30ml in 25 - 30secs?
                                I know this is a bit more of a general question, but I cant for the life of me remember the coffee course I did 6 months back!
