Hmm, my suggestion would be to stick with the double shot basket until you're getting consistent results - it's just generally a bit more forgiving especially when starting out.
You can use the single while dosing as I've mentioned above, however you can't then translate that grind setting to the double, while you can use the same grind setting for the single as for the double by adjusting the dose... wow that sounded complicated
- it isn't, see this post to see a simple method on how to use the single.
I use a VST 18g basket and can never prevent the squirting no matter what I do....
