Brent-
While I get a similar, albeit less pronounced bounce, that squeak you have at the beginning is not something I have experienced. I don't suppose you can tell where it's coming from? That might narrow the culprit down. It's loud enough that maybe you can narrow the origins down a bit. BTW- how cool is it that we can share stuff like that and get help from all over the world?
Hey David-
THANX for pointing out the single basket holds that much. I pull enough shots that saving 4g+ each time matters. Not to mention the slight reduction in caffeine I get each time. You just made my life a little easier, so thanx even though you didn't realize your contribution
After some very slight adjusting I now have my Compak set to pull good shots with 13-14g loads in the single.
I believe doing a purge is just a sound barista technique. It certainly isn't required on the Breville to get the group down to temp as you need to do on a HX machine that has been sitting unused for a bit. Maybe the way to look at it with the BDB is- the flush is a clean vs a purge. So how long to do it is really subjective. Do it until you feel clean!
Personally, I do not do a quick clean before putting the PF back in the group like some others here have already stated. I *DO* a clean/purge/flush after every shot, rinsing the PF and shot glass all at once. There certainly is no harm in doing one right before your shot even if you do a rinse after your shots. If you are seeing Phil McKnight doing this, or recommending it, then do it! I suspect he is more intimately acquainted with our machines than most of us.
The only time I flush before pulling a shot is the first time. I have the machine auto on, but with the PF not in the group head. When I first approach the machine I have to heat up the PF and that's when I prime it with hot water.
During a Barista class I was taught to take the PF out of the group because it will react with the gasket if it sits 8hrs+ unused, degrading the gasket quicker. This advise was for a commercial machine, where you leave it on all night and potentially with a different gasket material. Does anyone have an opinion on this practice? It may be less, or un-necessary with the Breville.
Also- at the end of the day/long session I'll do a couple back-flushes without any chemical. That seems to knock some grinds loose from nether-reagions.
Originally posted by DavidW1960
View Post
After some very slight adjusting I now have my Compak set to pull good shots with 13-14g loads in the single.I believe doing a purge is just a sound barista technique. It certainly isn't required on the Breville to get the group down to temp as you need to do on a HX machine that has been sitting unused for a bit. Maybe the way to look at it with the BDB is- the flush is a clean vs a purge. So how long to do it is really subjective. Do it until you feel clean!
