Hi guys,
I've been lurking around since December when I got my BES900. In the mean time - I've had to adjust the OPV once already, basically at about 230 shots it was kicking in at about 7bar. Thanks to Nic (hi Nic!) and his magic blog - that was one easy fix.
Mind you - now that I've done that about a 5 weeks ago, I've noticed that the pressure where the OPV opens has come down again - by about 0.75bar. Seems that the plastic-fantastic thingumabob is not that fantastic after all. No matter - I've got the Expobar E614 brass OPV waiting and ready to replace the OEM valve - muahahaha!.
Now - why I'm writing this is because for the past couple of days I keep hearing a faint hissing sound coming from inside. I am not sure where it is coming from just yet but I'm about to find out - I've cracked it open again. Has anyone experienced something like this? Rubber O-rings perished in less than 6 months? Which ones? Something else? What?
My usage is about a cup of coffee a day - and the machine is turned off again. The PF does not reside in the group head when resting and the rest of the maintenance is done quasi-religiously.
Ino.
PS: I recall reading about someone finding a nest of ants inside their machine. I did too - right in the bottom part of it, and boy what a royal pain in the proverbial it was to take it all apart and clean it up. Now that the base is back together, and there are no left-over screws and parts, I'll keep a better eye on what's going on underneath the machine. I really don't want to screw/unscrew some 30 assorted screws that hold the base together any time soon now.
Ino.
The manual says to use the single dual wall filter for backflushing. Is there a reason for that? I mean the rubber disk seems to fit the double basket fine, so the ONLY reason I swap to the single dual basket to backflush is because the manual says so.
