Not too late! I (and Australian consumer law) would still consider a machine with a $1500rrp 6 months after its warranty to be covered by statutory warranty. Don't hesitate to follow it up, how much of that warranty time have you been without your machine due to problems? These machines quite clearly have several latent design defects, once they go in for their first time I think Breville should be updating every known issue to try to prevent the need for them to go back time and time again. My machine has gone in 4 times (3 times for the same issue) I have had the o-ring replaced with a gasket, the group handle replaced with one with thicker lugs to stop the handle spinning out, a ball valve replaced, the opv replaced, a new probe set in the steam boiler, a new chip on the board, then a whole new circuit board, a new group collar (which I believe is from the new updated dual boiler - which required me to get a new group handle and naked handle which have a little cut out bit on the neck),then the NTC + wires for both the coffee and steam boilers, solenoid valve assembly, coffee valve safety set and coffee pump with thermostat. that's all...
It kind of seems that there isn't anything else to be replaced in there! My biggest issue was with my pre infusion not working as intended, that took 3 visits and most of the above parts for them to fix.
I found Breville to have good customer service but they wont offer anything to you, it took several emails directly to them to get the wheels in motion. The turn around time on the last repair was excellent with door to door service (and FINALLY a machine that worked as intended!)
