Breville BES900 Dual Boiler - Owners thread
  • and the wait for the replacement ulka pump continues, sorted solenoid issue, works but not pumping the waters OPV valves in a bag awaiting its lower friend to arrive argh! (venting)
    • Hey Guys
      need your advice, i have repaired quite a few BES900's and 920's but i'm stuck with this one.
      I replaced a faulty brew pump on this BES900 and then descaled the steam boiler which had quite a lot of scale built up.
      The machine powers up fine, both pumps prime the boilers and both boilers heat up just fine.
      When the machine gets close to 90 degrees, it trips the circuit breaker on my house which i haven't seen before.
      i thought i may have blow a thermal fuse on one of the boilers but i can replicate the issue over and over.
      Any ideas what could be causing this ?
      • It's one of the boiler elements, could be either. Once got enough some part of the insulation is breaking down / distorting enough for an erroneous connection to be made. Uncommon way for them to fail, but not unheard of. Have seen it myself in industry. It may or may not show up under an insulation resistance test, however it should be readily apparent which one it is if you only power one up at a time.
          Issued fixed itself, i think there must have been some water causing a short. It must have dried up after a day or two. Machine works fine now.
          • Well Update no 3.
            My third Breville BES920 has now failed. This one manged 5200 shots.
            Starts up but shuts down almost instantly.
            Sent it in to the service agent to examine. Three weeks later to look at it , they found a split in the boiler and faulty solendoid and a few other things. Fix cost with labour was not that far off a new machine and i stll have an out of waranty machine
            So after three units ( initial batch BES900, second BES900, then a BES920) i have finally given up on them. They are a good bang for buck but for me they are just too unreliable,I get no more than about 3 years out of them. Time to move to a diferent machine.
            • Originally posted by robertm View Post
              Well Update no 3.
              Have you checked out the Nuova Simonelli Musica? I think they are great value
              • Hey Guys
                i have a BES900 that is losing a significant amount of pressure in the brew boiler. pressure going in is 13 bar, coming out 7 bar. Replaced every O ring, no leaks, fully descaled and boiler looks shiny clean inside.
                I really don't know why its dropping so much pressure, doing my head in.
                Any ideas?
                • Solenoid not opening fully and diverting some water to drip tray?
                  • If anyone is after one of these, Bing Lee has their Black Friday 20% off today (29/11/19) on Ebay. With the discount the price is $699.20 delivered.
                    Last edited by CafeLotta; 29 November 2019, 12:03 PM. Reason: Correction, added off
                    • Originally posted by CafeLotta View Post
                      I was debating upgrading my old BES900 to an Oscar II etc but the deal on the BES920 was to good to pass up! $679 local pickup!
                        I replaced the pump and everything now working perfectly again.
                        When in doubt, replace the pump.
                        • Originally posted by PoidaGT View Post
                          Hey Guys
                          I'm curious where you're getting the measurements of 13bar and 7 bar
                          • So I picked up one of these second hand at what I thought was a cheap enough price. It was advertised as having a leak which I suspected was just the steam wand ball valve.
                            Once I got it home and opened up I got a bit of a shock. I don't think it's the steam valve itself, just the top o-ring. But also the boilers middle probe o-ring. Looks like it's been leaking for quite some time and a lot of the internals have rusted. I'm told it works apart from the leak.
                            Does anyone know if the rust going to be an issue? It's mostly around the steam boiler, ie the bracket and even the electrical connectors. :-(
                            • Update:
                              Just went to check the o-rings in question and in doing so some of the spade connectors broke off where rusted. I might have a go at soldering them back but this is looking like it might be better off used for parts.
                              • Upload a photo to Imgur and post a link, sounds pretty far gone
