Re: Breville BES900 Dual Boiler - Owners thread
If you want to make great tasting espresso, then every path of the espresso should be seasoned & at optimal temperature. The BES900 takes between 6 & 7mins to reach operating temperature & even with the element in the group head, the PF still wont be at optimum temp. I do use the Auto On function a lot, but if I get caught, I use the hot water spout to heat up the PF as much as possible & then run 2 or 3 seasoning shots. The seasoning shots also double as dial in shots as well, so theyre not wasted.
Cheers, Phil
Cheers, Phil
