Breville BES900 Dual Boiler - Owners thread
  • VST 18g and VST 22g work fine for BES900
    Originally posted by 4C5F4A585E2D0 link=1312978609/399#399 date=1316587033
    What 3rd party basket would people recommend? VST 18g or the synesso?
    The VST 18g and VST 22g both work fine on my BES900.
      Robert
    • Re: Breville BES900 Dual Boiler - Owners thread
      Originally posted by 3B3C293F3224026C6464645D0 link=1312978609/659#659 date=1319943683
      Always proofread your responses so you dont words out.
      I see what you did there ;D
      • Correction: Unscrewing the spouts NOT recommended
        Clarification/Correction:
        When removing the plastic insert, I strongly recommend that new owners avoid unscrewing the spouts on the portafilter (as has been recommended). Like emmanuel (in this thread), I did so and then the spouts did NOT align correctly. Removing the plastic bit without removal of the spouts avoids that problem.
        Dang! My first post and I left out a very important word: "NOT"
          Robert
          I unscrewed mine when removing the plastic. I was careful to replace the thin washer before screwing it back and my spouts align perfectly east west.
          Several owners reported losing their washer. it is easy for it to drop on the floor or into your sock. Without it you wont get it square.
          I am consistantly getting 11 to 12 bar and a teriffic brew quality. Perhapse I should cover up the gauge.
          Barry
            I would get it adjusted to the "correct" 9 bar pressure, you might have to adjust your grind a bit coarser to get the same pour. From the accounts of others, if you are an espresso drinker, you will get a better mouth feel.
            Might as well have it running at what is considered the "ideal" brewing pressure, regardless of your current results, as potentially, they might be a little bit better, and very unlikely not be worse.
            • Fix for misaligned spouts
              Originally posted by 597A696962445F6E75787A751B0 link=1312978609/663#663 date=1319958241
              Yes, I did the same: unscrewed spouts, retained and replaced washer, and still got the spouts misaligned. Unless there was more than one washer, I did the same as you, but still ended up with misaligned spouts.
              Solution: Added a rubber O-Ring to the washer (thanks, Home Depot!). By selecting the right size O-Ring, I was able to get the right alignment. Do not recommend Plumbers tape, as it is intended as a waterproof seal, and would not be adjustable to the degree (pun intended) desired, to get alignment.
              Feeling better: no longer walking around with a misaligned spout! ;D
                Robert
                phil sez:
                The BES900 takes between 6 & 7mins to reach operating temperature & even with the element in the group head, the PF still wont be at optimum temp.
                a bloke over on home-barista asked if the PID for the group heater made it into the production BDB machines. Anyone know for sure?
                -peter
                  Originally posted by 425140474141575E5E0702320 link=1312978609/666#666 date=1319993903
                  Hi Peter,
                  A thermistor is used to actively heat the group.
                    Originally posted by 42777A7D49557970707373160 link=1312978609/667#667 date=1320004803
                    Hi Peter,
                    looks like mark prince over at coffeegeek was wrong.  he said:
                    And heres where Brevilles next trick is. It features not one, but two PID controllers. One is working on the brew boiler, and the second one isnt where youd expect it: it is on the grouphead, not the steam boiler. The steam boiler is controlled via a thermostat thermister control (which is more precise than a thermostat).
                    http://coffeegeek.com/proreviews/fir...boiler/details
                    spewin.  i was hoping it has two PIDs, especially the on one on the grouphead.
                    -peter
                      ;D Nope- Mark is correct Peter. My foggy memory :
                        Originally posted by 15202D2A1E022E27272424410 link=1312978609/669#669 date=1320006132
                        perhaps you need a shot of espresso to clear the fog a bit
                        -peter
                          Originally posted by 67525F586C705C55555656330 link=1312978609/667#667 date=1320004803
                          No!  - a thermistor is merely a temperature sensor not a heater - it is part of an electronic circuit which is much better than a mechanical thermostat at maintaining a stable temperature.
                            Thats why I just corrected my statement :
                              Originally posted by 43444B46554C270 link=1312978609/657#657 date=1319921179
                              Ill advise what the service centre finds.
                              Dropped the machine off at the service this centre this morning. Since been advised that they are sending it up to Sydney service centre as advice from Breville is that it could be a couple of things, so to save on waiting for spare parts, best to send it up there.
                              Told it will take about a week.
                                Sorry Talk_coffee, I was having trouble following the course of the thread and didnt realize that your correction applied to the thermistor thingo - just wanted to make sure that the machine wasnt done an injustice. Perhaps the fog would have cleared for me too had I visited my Bessie 860 first. :-/
