Re: Breville BES900 Dual Boiler - Owners thread
forum n00b - or longtime lurker really
- here; howdy.
Has anyone had difficulties with varying 2-shot volume? (or do you use manual...)
Fairly frequently (which is maybe 1 in every 4 or 5 shots) I have to turn the shot off manually as its headed way over volume. Most often this happens if the shot timer is headed over maybe 35 sec, sometimes less. The rest of the time it cuts off nicely at around 60ml, no problem.
Ive tried the reset a couple of times, hasnt helped. Once I put a measuring cup under a freshly-used puck & let a second "double" run ... I was just about to stop it when it stopped itself, at 150ml, after nearly 70 sec.
Bar pressure is steady 9bars (it was 12+ till I had it adjusted). 18g VST basket.
Is it me or is it the machine? :-/
- here; howdy. Has anyone had difficulties with varying 2-shot volume? (or do you use manual...)
