Re: Breville BES900 Dual Boiler - Owners thread
Hi Phil,
I am a new user of BES900XL and I have the following concerns that need you advice, thanks.
1. Extremely high OPV pressure: I checked the inside wall of the machine after removing the water tank. The machine manufacture date seems to be week 35 this year (it reads as 1135). I assume all the units of BES900XL had been calibrated with blind filters in the production line already but I am wondering how my unit could get up to 12.5 bar gauge reading while extraction 35mil in 50 seconds? If the punk was over-dosing, I tried to grind the beans coarser to meet 9 bar reading and then the extraction time is around 10 secs only. I believed the OPV was acting during the extraction even the gauge hit 12 bar because there was lots of dirty water left in the tray. My grinder is pretty high-end conical blade type with infinite grids (Bezzera grinder). When the bean was ground sufficient fine (not to the grinders limit), the BDB cannot extract within 60 secs at all. Any comments regarding my units OPV setting?
2. The second issue was the PF burst-out in the fourth shot. I observed the high OPV could be one of the causes for the burst-out. Is the siliocn seal inside of the group head too soft? or the OPV pressure was set too high? I think both could be the cause. My unit seems having high sensitivities to pressure, so the fineness of the bean is also very sensitive to the quality of the shots. No matter how to tweak the dosing, it is very hard to get correct extraction time and volume without the risk of PF burst-out. Any comments on my findings?
Nick OY
Hi Phil,
Nick OY
dialing in my dose and grind in the double filter basket for freshly ground beans. I either over dose or under dose but just cant seem to find the right balance.
