Gaggia classic sparked and fizzed
  • Gaggia classic sparked and fizzed
    Hi,
    hoping for some advice. My beloved Gaggia Classic died.
    I flicked the switch and heard a faint fizz then a spark appeared behind the switch. I pulled the cord out ASAP.
    Is this something that can be fixed or is it new machine time? Granted Im not the most technically minded of people, but I think I could replace a switch if i could find one locally (in Melbourne). But if this was symptomatic of a larger problem then maybe its time for the old G to go.
    thanks,
    M
    Re: Gaggia classic sparked and fizzed
    Could it be fused?
    But Im no tech either, so not too sure what happened there
    I think there is replacement part for the switch unit....
      Because its electrical and it sparked, get it checked out by a service centre and ask them to let you know if its terminal or an easy repair. (Yes most of us may be able to replace a switch, but there may be other gremlins that can be, and need to be, found by qualified technical persons with the appropriate test instruments).
        Thanks for the replies. Off to a service centre I go...
