Silvia wiring question
  • Silvia wiring question
    Gday guys.
    Does any one have a copy of the electrical schematic for the rancilio siliva that they will be able to provide a copy of.
    i need to install an inhibit switch in the circuit, as my house in becoming a share house and i trust no one.
    cheers
    chris
    Re: Silvia wiring question
    Sorry I dont, but curious as to how you would stop others from un-inhibiting it?
    Also, if you know how to wire relays and such, cant you just break the active 240V (which is easy to find on just about anything - its the one that will kill you if you touch it :P ). But seriously... is that what you wanted to do?
    Standard disclaimer about voiding warranties, illegal wiring, and frying yourself applies...
      i under stand voiding warranty.
      I would install a 2 pole key lock switch ( sprevher + schuh model D7P-KM21 or simlair ) and inhibit the pump and the steam switch. This seems to be the most basic way to inhibit with still allowing the machine to warm up. I also have a few other mods in mind just waiting on the PID price then start changing stuff
        just covering myself!
        you should be able to intercept the original switches fairly easily - again I know nothing about the Silvia, but you could break the original switch wire - most like has a spade plug so you could put yours inline. Just a thought.
        Someone here mounted their PID inside the Silvia on the RHS so there should be plenty of room.
        Pics of your progress are a must
          RandyG has some good schematics ...
          http://www.frcndigital.com/coffee/Silvia/SilviaWorks.html
          ...or go direct to the source...
          http://www.rancilio.it/rancilio/download_page.jsp?flag=1&id_cat=14&id_language=3
            I cant remember where I found it, but several years ago I found a wiring diagram for Silvia, I still have a copy of it on file, in Word format. If you want to PM me your details I could email a copy to you, either Word or PDF format.
