EM6910 leaking grouphead at startup / when using hot water spout
  • Blues1143
    commented on 's reply
    No sorry - the machine went to a family member and have since gotten a BDB - didn't bother me enough in the end to try and fix but, by all reports, will likely be a partially blocked 3 way.
  • Howyabean
    Hi Blues1143,
    Looks like I am having the same issue with my EM7000.
    Did you resolve?
    Did you replace the 3 way Solenoid?
  • Blues1143
    Great thanks - yep did some further reading and confirmed there is no anti-drip valve.
  • Xanthine
    Just going from memory, I don't think the EM7000 has an anti-drip valve as it's hot water system is different to the EM6910. The 7000 uses a solenoid valve to control the hot water flow between the group head and the wand. You problem may be caused by a solenoid valve fault. This solenoid valve is not the same one as the three-way solenoid which releases pressure in the group handle. There is a spare parts manual for this machine in the documentation section.
  • Blues1143
    Hi all - not sure if it is appropriate to reactivate this thread but I have an EM7000 with the exact same problem as the OP (water leaking from group head on starting machine and when using the hot water tap). I have exposed the group head and removed the anti-drip screw as per the above advice. It could be staring me in the face but I cannot appreciate the blue valve being referred to in previous posts. Is the EM7000 part of this different? Please see attached photos. Any advice would be greatly appreciated re where to go next.
  • C00rara69
    Re: EM6910 leaking grouphead at startup / when using hot water spout
    Originally posted by 5F58415245544556514305370 link=1317170149/8#8 date=1318316624
    Sounds like your anti-drip valve is not functioning properly.
    Looks like you were right Espress Oh.  Did as you instructed, removed shower screen and anti drip bolt.  Noticed that the bolt was almost loose (ie no pressure required to undo), had a look at the blue float and had some black particles on it (coffee gunk?), cleaned it off and checked spring which was ok.  Then put it all back together by first screwing in the bolt and tightening with a nip.  Then put the showerscreen on.
    I then tested the machine and hot water spout and got no leakage so problem fixed.   ;D
    Then did a decalc cycle and found more of the black particles in the water (6 to 8 in total).  Bit surprised that coffee particles can get up into the plumbing...  never-the-less its fixed so thanks again Espress Oh!
  • C00rara69
    Originally posted by 4E455D574B4A48414B53240 link=1317170149/11#11 date=1318565427
    I dont think the problem has arisen as a result of a worn group head seal though
    Id have to agree, the unit is only six months old and only used once or twice on the weekend.
  • jaysonleow
    Originally posted by 474E48444C290 link=1317170149/10#10 date=1318562635
    it sounds like you may need to replace your brewhead seal
  • ngame
  • C00rara69
    Originally posted by 50574E5D4A5B4A595E4C0A380 link=1317170149/8#8 date=1318316624
    If this is the case, water will drip from the group head whilst the hot water tap is switched on. You could try taking of the shower screen, and undoing the Anti-Drip screw yourself using a size 12 socket. Be very careful when putting it back in, as it is brass and tightening it up too much will cause it to crack/snap.
    Any guides with images to do this? Ive found plenty of guides showing how to take of the shower screen but thats it. Just want to make sure I know what im in for before proceeding.
  • hovercraft2
    Once its removed, check that the blue valve is sitting comfortably, that the spring isnt snapped/gone slack, and that there is no gunk stuck up into the thermo block.
    I once fixed a machine which the anti-calcium filter mesh had split and the small anti-calc crystals were all through the thermoblock and copper pipes.
    Goodluck!
  • Georgea
    Originally posted by 582B2B697A697A2D221B0 link=1317170149/3#3 date=1317255621
    ok descaled but still apperas to be leaking.  Would it be worth running a few descaling cycles?  The water I use is spring water which may be high in calcium and causing excessive build-up.
    Remove the shower screens and unscrew the anti drip shower screw and check the silicon anti drip insert.  Youll probably find that it is either very dirty or damaged.  In either case this will stop the valve from sealing.
  • C00rara69
    Originally posted by 282B3E38323A372B3A352F285B0 link=1317170149/5#5 date=1317281278
    I dont know what the problem is, but just throwing this out there.
    When was the last time you did a chemical backwash?
    If you mean have I done a cleaning cycle with a cleaning tablet then no. Dont know where to access them from here in Jakarta. May have to order from australia.
  • specialpants
  • LaughingAtFate
    Originally posted by 5A29296B786B782F20190 link=1317170149/3#3 date=1317255621
    ok descaled but still apperas to be leaking.  Would it be worth running a few descaling cycles?  The water I use is spring water which may be high in calcium and causeing excessive buildup.
    Hmmm, it may be that you could have damaged the machine, especially if youre running high-mineral-content spring water in it without filtering first...
    Id say run descaling a couple more times, if this doesnt fix it, well, You might have kitchen art. :-/
