Ascaso - Inox Trio F.F 073711
  • Ascaso - Inox Trio F.F 073711
    Hi,
    I was hoping someone could give me some guidance on this machine. It is very old and I would like to try and find a manual or something I could start with to get it to a reliable workable state. At the moment it can switch on, produce steam, and hot water for the coffee pods but when I use the steamer i get a lot of steam out the back of the machine. I received this from work as they wanted to throw it out as it did not want to switch on the last time they tried to used it, also it kept breaking...
    I have basically started by cleaning all the water pipes, the water tanks, the group handles, and will soon try and open the boilers(which looks like little laptop hard drives). This is my first attempt at opening a coffee machine so please be patient.
    Re: Ascaso - Inox Trio F.F 073711
    A pic
      the machine
        Pretty sure they will be thermoblocks rather than boilers.
        Cant offer you much more unfortunately, but steam out the back sounds like a leaky pipe, should only be between the thermoblock and the groups or steam/hot water arms.
        Watch out for the electrickery
          Excellent thanks.
            I think this series had a brass brew boiler and thermoblock for steam.
            Site sponsor Di Bartoli used to sell Ascaso machines and would probably be a great starting point if you get stuck.
              Thanks for the info.
              I connected all up and gave it a test run. Seems like the steam form the back is from the second water pipe that lets steam off after the any of brass boilers were used, so that should probable be ok. The only thing that I could see that was wrong is one of the waterpipe connections is leaking. I am thinking that I should probable not open the brass boilers or thermoblocks as that seems fine.
