Sunbean EM6910 Group Head Seal Issue
  • Sunbean EM6910 Group Head Seal Issue
    Hi , Just searched on this topic last week and found no answers sounds like a comon problem. My seal was leaking and some people were on there 8th seal. So I came up with the idear of rasing the shower basket to firm up the seal. I got some copper wire and kinked it into a circle in a saw pattern then put in the under side of shower basket then pushed the group head over the wire it raised up the basket to a perfect seal yay. But I have worked out it is best not to leave the group head in the holder as when it cools down, the seal shrinks. So I leave the group head out of machin when not in use.
    Peter
    Re: Sunbean EM6910 Group Head Seal Issue
    do you mean the filter basket?
    do you mean portafilter?
    Im a little confused...
      Hi thanks for the spellcheak and Translation still learning.
      Peter
        no probs, I wasnt being picky but I wasnt sure whether you put the ring between the basket and portafilter, all in the handle, or whether you had done some complicated machine modification to move the shower screen
        So essentially youve "raised" your basket. This would have the same effect as a group head spacer / shim which you can get for some machines. I think sunbeam offers a cardboard shim, or some people make them up.
        FYI the group head is the "head" of the machine where you attach the portafilter / handle. Its not easy (if at all possible) to remove it.
        Happy tinkering
          I think I get it so you mean a portafilter spacer / shim. I am not sure I would like some cardbourd there at least copper is food grade.
            OK here is a review for portafilter spacer / shim. The copper kept on breaking on about the 4th pour. So I tried the cardbord it got wet with cleaning. So now have cut it out of a lid for a honey container, it can handel the heat and is holding.
              nice hacking! FYI the cardboard shims go (I think) under the group head seal, so they wouldnt get wet at all. If you search this site youll find plenty of people whove done the same.
