Baby BES900 in the works? BES840
  • #46
    Re: Baby BES900 in the works? BES840
    I was hoping this new machine would be a category killer like its older brother BCG800 and BES900 have and take Silvias position. I am surprised no CSer has bitten the bullet... :-?
    • #47
      Originally posted by 4941494E4442200 link=1323740977/44#44 date=1336997995
      aha, jump to 3:50 to see the difference between the thermoblock and thermocoil  Looks much better, but harder to heat which is probably one reason for the higher rated element.
      How does the 840 control pre-infusion? Does it pulse the pump like earlier models or control it softly like the 900?
      The thermo-coil does take more energy to get to the target temp controlled by the PID, but the 1700W element gives better response to changes in temp. The thermo-coil has a larger thermal mass so it is less susceptible to temp swings when shot run slower or faster than ideal, the PID does the rest.
      The pre-infusion is controlled in exactly the same way as the BES900, via some newly patented (applied for) technology. It does not uses pulses.
      Cheers, Phil
      • #48
        Hi Phil,
        Is Breville going to be the first Premium Coffee machine manufacturer to add a USB interface?
        Thank you for your contribution here.
