Jura Ena 5 - grounds stuck in grinder
Thanks snobs and andytidd! This also works for me !!! Really Genius!! BUT, once the problem is fixed, don't feed anymore rice since when the rice powder meets hot water and pressure, the grounds become sticky and may stuck the brew unit. This happened to me and I had to clean the drip tray/ground out-put to make the machine work properly. Anyway, using rice to fix the "Fill Beans" error is a rather good idea!
Genius!! I took the whole thing apart and realized that the issue was nothing coming through the grinder. After reading your post I switched the grinder setting to coarse and after grinding a few times with rice, it started to flow.Originally posted by snobs View PostHey it might worth a shot.
I had the same problem with my super auto machine and I dump 2 to 4 cups of rice and let it run for few cycle.
It fix the problem and remove some coffee grease which was stuck in the machine.
Genius
The rod tag was the answer no broken covers and the end of a lot of pain and searching....Originally posted by JasonBSteele View PostOkay - managed to do this in the end!
Unscrewed torx screws at the top corners
Took logo off back and unscrewed oval screw then pushed up the locking mechanism to release the back part of the panels.
Unscrewed oval screw at the front which holds in place a plastic rod/tag
Pull the rod/tag out and down, this will release the locking mechanism for the front part of the sides which should then easily lift off.
Hope this helps someone.
Hi pinnatifid, did you manage to get those panels off? I'm in the the same place with my Ena 5:Originally posted by pinnatifid View PostHas anyone figured out how to get the side panels off without breaking? I've got all the screws out, the rear tabs pulled up and released, the rear corner mounting points loose, but can't get the front/top/bottom of the side to release.
And if I need to break them, how do I do it without breaking the whole panel?
Thanks!
But I'm still unable to prise the panels off - can anyone give any pointers?
removing ENA side panel
Has anyone figured out how to get the side panels off without breaking? I've got all the screws out, the rear tabs pulled up and released, the rear corner mounting points loose, but can't get the front/top/bottom of the side to release.Originally posted by noidle22 View PostThe side panels dont come off the Ena machines. Not any way that I have found anyway. You have to break them to get them off. You can slide the top and bottom back and release some tabs but you need to snap the front mounting points. It's ok once you put it back together because it holds together ok.
Thanks!
If the back logo doesn't turn, try harder or it might prise off.
How to pull off the back logo in a Jura Ena?
I have a Jura Ena³, and I could not make the back logo rotate. I do not seem to be able to get a grip on it in the first place to try and rotate. What is the secret?Originally posted by nwood View Post…ENA 5, the logo on the back rotates and comes off…
I have the oval key but I can't take the side panel off, could you tell me how to ?Originally posted by nwood View PostI've just purchased an Oval Key screwdriver from the US to allow me to get into my ENA 5, the logo on the back rotates and comes off revealing an oval bolt, there is another one of these in the center of the front of the unit behind the cover when you remove the drip tray.
Where are you two located? I'm happy to pass the Oval Key on when I'm finished with it.
Hi, It's been a while since this original thread was started but I thought I had better chip in with a few helpful tips regarding the Ena grinder. The Jura Ena machine was/is the slimest auto on the market which means that it is very tightly designed to maximise the available space on the inside to fit brewer, grinder, heater etc. There are a reasonable number of concealed fixings to maintain the outside appearance.Originally posted by mdubskee View PostWe had a bit of an accident in our house today. I needed to empty the grounds in my machine, and used an old bag of coffee beans. Before I got a chance to clean up, my mum then poured the used grinds in to the machine.
When I have observed our workshop technicians removing the grinder it is quite a process to remove the cover, remove the power board and another sub-assembly to then gain access to the grinder housing. Certainly coffee machines are not the most technical pieces of equipment that all of us have worked on but they do take practice.
Looking back at the original post I think mdubskee's Mum may have put the wet grinds back into the grinder. That wouldn't have been good news for any machine.
The Fill Beans message is indicated on the machine when the brewing chamber encoder senses that there was insufficient coffee delivered into the brewing unit. The message will remain until the next successful coffee is made ie the beans are refilled and then a coffee is made.Originally posted by MalleetankMy Jura Ena has stopped working, won't grind beans and has message "fill beans" even though it is full. I think it may be clogged up, would this key help me unclog the machine?
It sounds like you have checked that you have beans. Check for any obvious restrictions inside your bean hopper. Disconnect the power to the machine. Remove the clear lid, remove your beans and vacuum any excess grounds. You can remove the protective shield (hex drive required) to gain access to the top of the grinder to remove any excess coffee beans and check for blockage. Wipe the internal surfaces of the bean hoper so that any new beans will run freely within the hopper. Refit the protective shield. Re-connect to power. Perhaps run the grinder a couple of times without refilling the beans, then put some beans back in and retry.
If that doesn't resolve the issue I suggest a visit to your local Jura service centre.
Wayne
Hi, did you manage to get access to your machine with the Oval Key? My Jura Ena has stopped working, won't grind beans and has message "fill beans" even though it is full. I think it may be clogged up, would this key help me unclog the machine?
Dropping Problem with Ena 5.
I am having dripping problem with my Ena 5. It drips so slow and probably I would have got just a tea spoon of coffee. I would appreciate response
Thanks. I tried a clean cycle even though I had run one not too long ago, but it didn't make any difference. Looks like I can get that oval tool for about $15, so I guess it's either try it myself with that or pay a minimum $85 charge to bring it in for service.
Have you tried running either a rinse or clean cycle through the machine. I would recommend trying a clean as this may flush out some of the ground coffee that had made it deep into the internals.
If you search 'jura oval' on eBay you will get some results for the tool.
