Any tips on getting some good micro foam from the oscar? I'm a barista and can handle the steam on a huge 3 group machine but I just can't get the knack for this oscar, any tips would be much appreciated
Sorry but there's no snake oil or silver bullet. Really it just comes down to practice and figuring out what works for the machine. When I had my Oscar it was a beast in terms of steam, and ended up getting a new tip for it but in the end it was just learning the machine. It wont steam as easily as big 3-groupers as they have drier more constant steam from the bigger boiler, and so the Oscar will be much more variable. It would definitely be worth getting yourself a new steam tip with smaller holes - around 0.9mm maybe, probably 4 hole - but in the end it's just trial and error till error become success!
Cheers man, I thought it may have something to do with the wetter steam but yeah it is definitely a learning curve , going from silky milk at work to bubbly milk at home is kind of frustrating but I'll just keep working at it
I have a Oscar with a number of modifications which has turned out a really nice machine. Basically what I have now is a machine with Musica specifications but without all that being. Oh, and no doser.
The mods are :
OPV or over pressure valve, this allows the brew pressure to be set at a critical 9 bar.
Anti vacuum valve; this stops the boiler from creating a vacuum when it cools which means you no longer need to remember to open the steam valve when switching the machine on each morning. It also means I can set it on a timer so it is warmed up ready when you wake up.
Dual Pressure Gauge, this allows the operator to keep an eye on both the boiler and brew pressures. The adjustable boiler pressure dictates the water temperature so I have control.
Sound insulation, as the Oscar has a plastic body the vibrating water pump is noisy. I have installed sound insulation around the pump to quieten it down.
Giggluers , these are restricters in the thermo syphon pipes to the group head which slows down the flow of hot water to the coffee grounds. This helps to prevent channelling giving a more consistent brew.
Steam Wand; I have restricted two of the four steam holes which creates better microfoam in the smaller milk jugs used domestically.
[COLOR=#000000][FONT=sans-serif]I think the Oscar is a great machine for the serious home barista and with these modifications it is capable of producing espressos equal to far more expensive machines. It may not look as flash as the high bling stainless steel machines but is infinitely more practical and easy to clean. I've been making some very satisfying coffee with this machine but it no longer satisfies my need to fiddle so I'm now restoring an old La cimbali junior.
Reason: Removed commercial content
Hi guys! I have just bought a s/h oscar and wondered what people are using to soften there water? I live in Perth so the water is pretty hard and I don't think my filtered water from my Samsung fridge water dispenser will be enough. I see you can buy a little canister to plug into your inlet hose for other espresso machines on the market but that doesn't help the Oscar with its water tank being how it is. Do most people use a under the sink type canister solution or is there an alternative?
Reason: spelling
Just finished the same mods as Me2 bar the two gauges.
Ive just got the brew pressure gauge connected to a prtafilter. A more permanent solution some day but enjoying the goodness my revamped Oscar has to offer.
Just thought I would say what a great help Gianni from Elektra has been.
I bought the kits advertised for a good price. All up just over $100 posted. He posted it out via EMS and got here in less than a week.
I got a quote for a double fitting from a non sponsor here. He quoted $70. Gianni quoted about $30 delivered from Italy.
The service and quickness in emails is really great, both Pre and Post sales. If you need anything Oscar, by it from him.
