Hi All,
I am new here so take it easy one me ok
I have a problem with my Sunbeam EM6910 and I am hoping someone out there can offer some advice.
My unit is approx 6 years old and to be honest has been a little unreliable. It has developed a problem and if its not a quick fix it will be upgrade time.
It fires up ok and the light changes to green or red (I forget :
), indicating that its at temp an ready to go. However when I push the go button all it does it make a lot of noise.
I am not sure of the correct terminology but normally you will get the intermitten noise where its priming or something about 4 times and then the water will flow. Now I get the pulse sound continually and no water flow. I have the manual at home and was hoping it is something I could fix myself as I do not want to spend anymore money on this unit. Does anyone have any suggestions as to what might be the cause?
I should point out it has happened twice before. The first time was when I had it in storage for a year. This was fixed when I took it in for a service and to have the group head collar replaced. The second time was again after a period of none use which fixed itself after I walked away in disgust.
Someone has suggest it may be an airlock but I have no idea about coffee machines. If anyone has any suggestions or ideas on the cause I would appreciate it.
), indicating that its at temp an ready to go. However when I push the go button all it does it make a lot of noise.I am not sure of the correct terminology but normally you will get the intermitten noise where its priming or something about 4 times and then the water will flow. Now I get the pulse sound continually and no water flow. I have the manual at home and was hoping it is something I could fix myself as I do not want to spend anymore money on this unit. Does anyone have any suggestions as to what might be the cause?
