EM6910 help
  • #31
    An update for your all!
    WHAT AN AMAZING DIFFERENCE HAVING A GOOD GRINDER MAKES!
    I picked up a second hand Rocky from one of the sponsors and this morning i made a cappuccino and it was AMAZING. The puck popped right out of the group handle when i gave it a little tap - no mega soppyness/only half popping out.
    I put two sugars in before i tasted it and nearly died from the sweetness lol.
    SO HAPPY
    • #32
      Oh and i must've got my dosing and tamping right because i did have a dent from the shower head which seemed normal, but no channeling or anything.
      • #33
        hi drovers, i'm only a learner myself and have the same machine as you (em6910) but i have the sunbeam grinder (em0480). do NOT downgrade to this grinder. i'm actually on the hunt for a smart grinder myself when i find one within my budget. the sunbeam grinder has too big a gap between each increment i've found, and other family members who have trodden the same path as what i am now, say the same thing. one notch will be too fine, the next too coarse. you can work around it but its an entry level grinder for a reason i think.
        • #34
          Hi Drovers,
          Glad you found something that works - enjoy!
          Pete
          • #35
            SO HAPPY
            Terrific effort! It sounds like you've also improved your dosing. The pucks should pop right out in one piece like you mentioned. You were probably under dosing a few months back with the old grinder; if you still have access to it, you should do a side by side comparison.
            You'll get better each day - and try experimenting with different grind size/doses until you find something that works for you.
