Originally posted by drovers-sunrise
View Post
You'll get better each day - and try experimenting with different grind size/doses until you find something that works for you.
While i was there, i noticed that the two that we put in the other day were the ONLY shims in the grinder. I was under the impression that there were supposed to be two that were pre-installed.... Anyway, i just threw in the other two that I had. Gave it a good vacuum out while I was there. Hopefully this will help too!
