EM6910 problem...
  • EM6910 problem...
    My Em6910 is loosing pressure at the group head i think...
    When i lock in the handle and basket and start extraction i get an initial spurt of water out of the group head into tray...
    Only at the begining ...I assume a seal is on the way out...Can anyone advise please ???
    Re: EM6910 problem...
    What reading does the pressure switch give?White,yellow,tan,red?
      My guess (and it is an educated one) is that either your seal is cactus or your collar has worn down. Either or both may need replacing..
        Pressure is still pretty good upper mid range 30 seconds for 60mls....
        I have a new brew head seal to put in...
        If thats not it i will look into collar replacement...Any starting tips for that ????
          New seal in and all working ok again althoiugh had to adjust grind and dose as pressure is now up and correct...
