I have been lurking around here for a while and taking in the wealth of information that you all have to offer and was hoping someone may be able to help me with a problem has recently started with my EM6910.
After tempering the milk, you turn the dial to stop the steam but the knob seems to have moved toward the operator over time and the steam continues to run for up to about 30 seconds then it peters off and stops.
i am mechanically minded but have never worked on a coffee machine before. I liken this problem to a tap washer being worn out and the spindle being rotated further than it should causing the tap to leak.
I downloaded the service manual that i found the other day which gives a breakdown of the components but thought someone might be able to give me some advice as to weather i can pull the machine apart and conduct an easy fix
