Tripping Silvia
  • Tripping Silvia
    Well it had to happen . I took Miss Silvia on her last trip to Strathford on the Avon over Xmas. On the last evening of our stay, the power to the house went out. After several occurances it was easily determined the Silvia was tripping the house circuit breaker, even though she on but was not in use. The next morning, by habit, I turned it on and made coffee as usual, no probs.
    When we got home, I was all set to prissy and clean, but no sooner had she sucked up a boiler full of descale, the house circuit blew again. Luckily CosmoreX in ACT services Rancilio and after speaking to Mick this morning he seemed confident it would be a heater element and I could pick it up early next week. Since I was going to change the Group head seal anyway, hes going to do that for me too. ;D
    Ill keep concerned Siliva owner appraised of the fault details so they can recognise the symptoms should they occur. Bought new in Melbourne, November 2005.
    Boris.
    Re: Tripping Silvia
    So does that mean a new boiler?
    Id like to know how many boilers have had to be replaced within 3 years of new.
      Re: Tripping Silvia
      "So does that mean a new boiler? "
      Yep. Went to see Mick this morning. He has replaced the boiler and element (its a one piece construction). However during his testing he believes the new boiler is heating up way too quickly, hence is now asking Rancilio questions about recent changes in boiler design. The boiler is physically slightly different to the old one. Still bolts in the same, external piping points are a little different. He believes it may be in response to consumer concern over heating up times, but is going to check to be sure. Now thats a tradesman.
      Boris
        Re: Tripping Silvia
        Unfortunately, Rancilio decided to abandon the old bolt-through elements because of problems with leakage at the boiler junction. It wasnt so much a case of the seals, but sealant failure.
        The new welded-on setups dont leak, but with that convenience comes having to buy a new boiler and element--- and at great cost.
        Seems an unnecessary waste. Surely a return to the independent element with modifications to prevent leakage can be done.
        --Robusto
          Re: Tripping Silvia
          Yes,
          One would think so Robusto, a very strange decision that one :-?
            Re: Tripping Silvia
            Does a new boiler come complete with thermostat switches attached or do you have to stick the old ones back on? I thought I read somewhere that Rancilio altered the switches in later models to lower deadband or something along those lines??
              Re: Tripping Silvia
              Not 100% sure, Mick didnt specifically mention new ones, so Im assuming it doesnt, just use the old ones. Ill find out in the next day or two I guess. :-?
              Boris
                Re: Tripping Silvia
                Thermostats were changed from 110º down to 100º after complaints the water was too hot, and produced too much steam during extractions.
                I would imagine thermostats do not come with replacement boilers.
                -Robusto
                  Re: Tripping Silvia
                  can you keep your old boiler?, im in melbourne and would like to play with it, ive a few ideas up my sleeve, ill give you a few $$ for it
                  cheers
                    Re: Tripping Silvia
                    cheers
                    This sounds deliciously intriguing. Can you reveal what fiendish plan you have yet?!!
                    --Robusto
                      Re: Tripping Silvia
                      I didnt ask, I guess it would be returned. If your keen, PM me.
                      Anyway, Attilio called today to advise they have discovered the problem. They have been sent 110V USA varients of the replacement boilers, not 240V AUS varients. So now thats sorted, should be smooth sailing to a good as new Silvia, soon destined for a new home...
                      Boris
                        Re: Tripping Silvia
                        unsure yet, curiosity at the moment, either hacking it up to make a model steam engine, or maybe eventually making some sort of Medusa silvia
                        mainly though, Ive a serious lack of junk bits and bobs since emigrating from the UK 3 months ago, and I really need to start filling up my drawers with useless stuff and junk that may be useful some day. ;D
                        cheers
                        --Robusto
                          Re: Tripping Silvia
                          I know where you are coming from Bleugh --- turning that junk into useful "art" sates something in all us shed blokes.
                          But there are othertimes when I envy those other blokes with nothing but cleanliness in their sheds -- and room to move.
                          -Robusto
