I'm wondering if people out there have tested the temp you get out of the group on your ranchilio.
I've been questioning if my temp is too low on my machine so have done a crude test. I was hoping some of you could do the same and see how my machine compares.
My test.
1 standard ceramic gen purpose mug
1 thermostat (frothing type)
Test:
Warm up machine for 30 min (flush group to during this time to bring up temp)
Put thermostat in mug and run water from empty group (hold mug up do it s close as possible o group)
Run water until light goes on hen stop.
While element is bringing boiler o temp keep water in mug
As soon as light goes off spill water out of mug hen run water no empty mug agin
Run until light comes on hn stop
Again keep water in mug
Repeat this process fo 5-6 times
The last 3 times or so my temp. was consistently the same.
While running water into cup temp would rise to 85. Then drop to 81.
I would have thought ths is too low but it may be right when portafilter is in and pressure builds.
It would be good to see what others can get the max temp to.
Ogi
My test.
Test:
Ogi
