6910 double shot cutting out
  • 6910 double shot cutting out
    The double shot program on my machine gives the three priming buzzes and then nothing. I've only had the thing for a few weeks and the button used to work fine. Anyone else had this?
    You've not inadvertently programmed it for essentially zero output? Maybe try programming it again with your desired output volume (note that this needs to be done with coffee in the basket).
      First try resetting to the defaults.
