Silvia wet puck
  • Silvia wet puck
    I have recently been getting wet pucks even when serving quite nice shots....not so wet that they dont pop out with a gentle knock, but certainly quite a bit of liquid residue on top. Still tastes good !
    Any thoughts?
    1. If the shots are good, don't worry about it.
    2. Sounds OK - I get water on the puck but not puddles.
    3 You say recently. Assuming you weren't getting wet pucks before what has changed?
    4. What coffee are you using now?
      Usually a lower dose with a finer grind can leave a little puddle on top of the puck if the potafilter is removed straight after the shot is pulled,
      But like flynnaus has mentioned it does not matter.
        Nothing has changed....the only thing might be that i have been using some very fresh coffee...only a few days old, from Gridlock Coffee ...I have been using beans from this roster for around 4 weeks so other than the freshness, everything is the same.
        In the past I have had quite dry pucks that pop out with barely anything left in the basket....maybe its just the over-fresh beans!
