Question for the Silvia fanatics.
  • Question for the Silvia fanatics.
    Has anyone heard of a Silvia being fitted with a commercial C-lever steam tap ??
    Iv looked into it and it can be done reasonably easily using all genuine Rancilio parts and some light engineering.
    Have you got a picture of what such a tap looks like?
      (EN) Rancilio C-Lever - ergonomic steam wand - YouTube
        Talk to coffee machinest he turned his into a pid dual boiler with a fixed hot water tap. It was amazingly lol!
          Looks like it might if that thread on the entry is the same, and long enough on the C-lever
          Silvia
          C-lever
            The wand thread is the same and lines up , so the V3 wand will screw straight on.
            The rear thread is larger 3/8" vs 1/4" , so that needs to be drilled out larger and painted to prevent rusting. The factory pipework will bolt up using a 3/8" - 1/4" adaptor from the pressure transducer on an Epoca.
            The front panel also needs to be enlarged to fit the C-lever , otherwise it will all bolt together.
              Post pics when you're done
                Nice idea,..but i imagine it may look a little out of proportion on the Silvia.
                Have you considered possibly using one of the smaller "toggle" valves ,..as used by Bezzera. ?
