Iron thermocouple washer question
  • Iron thermocouple washer question
    Will using an iron washer against the brass boiler cause a reaction ?? Should i use stainless ones instead ??
    You should use brass
    Galvanic corrosion - Wikipedia, the free encyclopedia
      So how many people are using a thermocouple or the auber pt100 RTD ??
        I had a Type-T on my Silvia retained by a machined block of UHMWPE which fit in the bracket for the brew t-stat (replacing the t-stat).
