Originally posted by teds01
View Post
It could still be moisture - can you beg, borrow, or steal a hair dryer, or better still, a heat gun ??.
As Steve said, it was worrying that the RCD tripped as soon as the machine was plugged in.
It is still worrying that it now trips as soon as it is turned on.
But my biggest worry is that the only testing we can do is change something, then see if the breaker trips, or not.
There are so many what-if's and maybe's here, and we are working from an unknown starting point.
Seems like your socket / connections were reversed before you got it, so who knows what other changes have been made.
I looked at the images on the web too. I only found one with the brown wire on top - most were blue, but it's not that important.
If they were reversed at rear of the socket, and everything else was OK, the machine should still work anyway.
The only problem I see is that there would be "live" wires and terminals throughout the machine with the switch off.
This increases the number of places where moisture could be causing earth leakage which would trip the breaker.
It's probably not what you want to hear, but if all else fails, you could try cutting all the cable ties holding the wires together, then following the pictorial circuit diagram, but ignoring the colours, physically trace every wire from end to end. The connections to the switch and the boiler must be exactly as shown. For 220/240V the elements should be in series. The wires to the solenoid should go to the two outer terminals. The wires to solenoid, the pump and the two thermostats can be connected to either terminal, as long as the right pair of wires are connected to each component.
If every single wire/connection is right, then one of the components must be faulty, but then you still have to figure out which one.
Maybe you need to start a new thread asking if there are any CS's in your area with tech ability and test equipment, & willing to have a look at it.
Unless it is fairly new, it may not be worth taking it to a pro to get it fixed. ( or shipping it to and from Brisbane )
Cheers, D.G.
