Originally posted by pcrussell50
View Post
Breville BES920 Dual Boiler - Owners thread
Hi Peter, thanks for your help. I have the dynamic duo so it’s the Breville smart grinder. Irrespective of the level of crema, I made a coffee this morning and it was pretty bad. Certainly a lot worse than I can get out of my 6910 sunbeam. I’m a former barista and cafe owner so I think my technique is pretty good so that only leaves the beans but it seems strange to me that having tried 3 different bags of beans (2 non supermarket) that I’m getting such poor quality coffee. I bought a new bag today roasted on 19th feb so I’ll see how those go and maybe I’ll take a video.
By the way, sorry if I came off arrogant...
How are your other fundamentals? Are you seeing reasonable pressures 8-10 bar (it will decline during the extraction and finish at lower pressure and faster flow, which is normal), and reasonable time (25-40 seconds)?
If you are able to get inside those time and pressure windows, AND have fresh beans, you should have good crema.
Otherwise I am at a loss. But it should work if you're not getting channeling... Which I am increasingly suspecting. All an espresso machine does is deliver water at several bars of pressure, and a set temperature (which is what the BDB is particularly good at). If you fail to get crema with your known fresh beans and within those time and pressure windows, it's time to borrow a mate's known good grinder. The smartie is an adequate grinder. BUT if it's brand new, you may need a couple-three kilos of beans through it before the burrs are seasoned. Brand new unseasoned burrs can definitely cause channeling and erratic extraction.
Keep us informed how it goes.
-Peter
Have been using my BES920 + Smart Grinder Pro every single day (except when I go on holidays) since August 2014 and it has never skipped a beat.
Recently the pre-infusion pump has started playing up, and the descriptions in this BES900 thread matches my situation!
Any other BES920 owners have this issue? Luckily I'm still within my 5 year extended warranty period!
Hi Peter, you are a genius!Originally posted by pcrussell50 View PostBy the way, sorry if I came off arrogant...
-Peter
Ok so tonight I pulled out my old sunbeam cafe series grinder that I used with my em6910 and my old machine....I ran a double shot through both machines. With the smart grinder on both machines I still got a poor extraction with flimsy crema. I then used the sunbeam grinder and....boom! Beautiful shots with crema you could have a bath in!
So in short, the smart grinder is the problem...so what on earth do I do next other than putting up with awful coffee for several weeks in the hope that the burrs season or is there a way to fast track the process? Thanks so much for your help!
Hi, yes I did - it’s definitely not an issue with the fineness - I took it right down to the point where nothing came through and worked back from there. The issue seems to be with the clumping of the coffee coming out of the grinder causing inconsistencies and weaknesses within the coffee thereby causing channeling (see attached).Originally posted by prydey View PostDid you try grinding finer with the smart grinder? Sounds like you just need to go a bit finer.
So! you have two coffee machines, a grinder and an operator, you automatically assume its the grinder, have you considered it could well be something to do with the technique of the operator?Originally posted by thecafeninja View PostAlso I tried a shot through both machines and same issue with channeling on both so it’s the grinder that is the problem.
Can you tell us a little more about this? I've never experienced it.Originally posted by pcrussell50 View PostBUT if it's brand new, you may need a couple-three kilos of beans through it before the burrs are seasoned. Brand new unseasoned burrs can definitely cause channeling and erratic extraction.
I was talking about conical burr grinders in general... Or at least the "titan" (commercial grinders used in home environment). I have a grinder with huge conical burrs (from a Robur) and it became way way way less channelly, more consistent, and ground nearly twice as fast, after I ran about a kilo of parboiled rice through it. (Never use regular hard uncooked rice. In fact many grinder makers warn specifically against it.)Originally posted by Yelta View PostCan you tell us a little more about this? I've never experienced it.
I have no specific experience with the Smartie, but being a home-use appliance and not a commercial grinder, I would have expected Breville to have done some form of pre-seasoning in order to reduce customer dissatisfaction over a new machine. I only suggested the need to season, based on 'Ninja's description of his symptoms. Upon further reflection, that kind of behaviour also comes from the case where the outer burr ring is not perfectly concentric with the inner burr, so a possible manufacturing error comes to mind as well.
Further reading of much out there, here is a thread I picked at random: https://www.home-barista.com/grinder...ts-t39850.html
-Peter
Interesting, have had no experience with conical grinders, only flat burr.Originally posted by pcrussell50 View PostI was talking about conical burr grinders in general... Or at least the "titan" (commercial grinders used in home environment). I have a grinder with huge conical burrs (from a Robur) and it became way way way less channelly, more consistent, and ground nearly twice as fast, after I ran about a kilo of parboiled rice through it. (Never use regular hard uncooked rice. In fact many grinder makers warn specifically against it.)
-Peter
The only affect I have noticed with new burrs is they do grind quite aggressively for the first few days, never a problem with extraction.
No I have two coffee machines, two grinders and have run shots through both machines using both grinders. One grinder produces perfect shots through both machines....and it isn’t the smart grinder! I’m pretty sure it’s not me that’s the problem!Originally posted by Yelta View PostSo! you have two coffee machines, a grinder and an operator, you automatically assume its the grinder, have you considered it could well be something to do with the technique of the operator?
